Drag Bar
Old Nov 2, 2012 | 10:54 AM
  #41
TwoFast4Lv's Avatar
Originally Posted by 1961ba427
I've got enough of that to deal with running the spooled 12 bolt....getting tired of it in a true daily driver. It's extremely loud and clunky and generally ill mannered, but at least I haven't had to worry about spitting out gear teeth in the lil 7.5". Going to a posi and some new gears soon. Do you think the 24mm third gen rear sway bar will be a good compromise upgrade for a dd car?
I ran big SST Road race bar when this was taken.
Old Nov 2, 2012 | 11:11 AM
  #42
BMR Sales2's Avatar
LS1Tech Premium Sponsor
That is a decent launch for a more "street" oriented rear sway bar but you can still see that driver's side is still lifting the tire higher than the passenger's side so it is still twisting the chassis up a bit. I would think you would still see a pretty good improvement going from your current rear sway bar to a good anti-roll bar.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old Nov 2, 2012 | 12:13 PM
  #43
quik95lt1's Avatar
heres your xtreme bar in action car was running mid 1.3x's 60's this day off a 2500rpm footbrake all motor
Old Nov 2, 2012 | 04:54 PM
  #44
TwoFast4Lv's Avatar
Flip back a page or so and you will see my new bar That was only a 1.32 60
Old Nov 2, 2012 | 05:02 PM
  #45
1961ba427's Avatar
Where can I find the SST rear sway bar? Googled it and found nothing, but Hellwig and some green ones called ST, but no SST.
Old Nov 2, 2012 | 05:37 PM
  #46
TwoFast4Lv's Avatar
Not even sure if they are still around. I sold that one. I bought it back in 97 as a set
Old Nov 2, 2012 | 06:54 PM
  #47
1961ba427's Avatar
Do you remember the diameter of it? Did it attach with stock style endlinks or something stiffer?
Old Nov 3, 2012 | 12:13 AM
  #48
TwoFast4Lv's Avatar
I want to say it was 22 or 24mm. Poly ES links. I dialed them in the way MADMAN told me to.
Old Nov 3, 2012 | 01:15 AM
  #49
fex77k's Avatar
My mark williams was a handful before i put a roll bar and a wishbone setup. Runs true now.
Old Nov 3, 2012 | 07:51 AM
  #50
1961ba427's Avatar
Thanks for the pic Ellis. I'm going to try to get by with an 89 WS6 24mm rear bar and some tuning of the end links for preload for my 4th gens. This thread has gotten me thinking about a true race oriented bar for my 61. It has never had a rear sway bar of any kind.
Old Nov 4, 2012 | 01:41 AM
  #51
TwoFast4Lv's Avatar
You bet! Brain told me to set it dead neutral with me in it. I just used washers for shims
