Instant center and pinion angle
I have the BMR th400 crossmember that allows you to adjust the instant center. I also have a adjustable tourq arm. I'm guessing that every time you change the instant center on the crossmember you would have to readjust the pinion angle? Or am I wrong? What is a good starting point on the crossmember t.a. mount (top,bottom,or middle)? One of the guys from bmr said the higher the harder it hits but for a shorter amount of time and the lower the softer it hits but for a longer amount of time.
