Help...PLEASE!
Old Nov 7, 2012 | 02:22 PM
missinmym6's Avatar
Default Help...PLEASE!
Alright guys. I did some horse trading and ended up with a 93 z28 with a 94 motor/trans. The car didn't run when I got it, the guy built a motor(scat crank, forged rods and slugs, cam, head work, and paperwork to prove) and did a full MSD ignition setup at the same time. Well, he was wiring challenged and couldn't get the MSD 6al box wired. I got the car, wired the MSD and it finally fired.
When I got it running it ran like sh*t on the low end. Once it was about 3k it ran alot better. Well I went out one day to fire the car and had nothing at the key. Turns out it wasn't sending power to the starter. it sat for a month before I could get a look at it.once I did I used a manual starter switch to see if it would turn over that way. Which it did, but won't start. It would try but not fire. I looked at fuel pressure and its super low. I can hear the fuel pump running, and it sounds fine. but I'm only getting 5-10 psi. All of this, the hard start and no fuel pressure appear to have happened at once.
Is there something simple I am missing?? Just seems ironic that I have no power to my starter and no fuel pressure..
Old Nov 7, 2012 | 02:54 PM
1hotlt1's Avatar
Fuel regulator, check fuel pump, get another guage double check psi, check fuel lines front to back, double check the harness from started. Double check everything.
I had the same problems I just had to double check one by one every single plug, wires, fuses, fuel regulator, fuel filter ext. Finally is running good.
