Beehive springs Strikes again.(edit) Now called : Engine rebuilt 2013 .
According to PAC Racing ( because they have inspected my springs ) told me the springs specifications are the exact same as a CompCams # 26918 .
They didn't say it was a CompCams but the specs. are the same .
So it is not a PAC1218 faillure because this spring is not a PAC , it is a BeeHive spring faillure , yes.
So this said here's the story .
Earlier summer 2012 I broke a Bee Hive ( edited ) spring for no particular reason just cruising around .
Lucky enough I didn't do any damage so I've replaced the broken spring and keep driving it all summer.
( pics. from earlier this summer ) :
Today ( this morning on Nov. 15 2012 ) I broke another one but this time I was not that lucky.
The valve is stuck there ( probably bent ) .
I don't know how bad it will be when I'll lift the head but we'll see pretty soon.
Sad way to end my 2012 season.
Anyone else breaks BeeHive springs like that ?
They are rated .600 of lift and 1st time I broke a spring my cam specs. were : 223/230 .565/.565 112 LSA and 1 month ago I replaced the camshaft by another with the following specs. 228/236 .576/.572 110 LSA .
I don't think the cam has anything to do with breaking the springs with the specs. I have even with the new camshaft don't you think ?
Anyone else breaks PAC 1218 springs like that ?
I cannot answer that question , too technical for me but I have bought the heads from Lloyd Elliot as a LE2 package back in June 2010 but it got installed only in November the same year as a winter project .
Here's a "copy and paste" of my actual motor setup :
Lloyd Elliot LE2 package. www.Elliottsportworks.com
-Fully Ported heads milled 0.030" with 0.56cc chamber, casting 10128374.
Manley 2.00/1.56 6000 series valves.
PAC 1218 bee hive springs (145 lbs seat and 340 lbs open)
Steel retainers and locks.
205 cc intake port flow about 275/190 CFM.
-12.05:1 Comp. Ratio , 240PSI Compression.
-CompCams Pro-Magnum Roller rocker 1.6:1 7/16" studs "NSF" (None Self Aligned).
-850-16 CompCams Hi-energy hydrolic roller lifter.
-7937-16 CompCams Hi-Tech Pushrods 5/16"X7.050".
-300-8245 ARP Perma-Lock 7/16" 12pt Rocker arm nut.
-MR-1896 Sealed Power 5/16" Guide Plate.
-Fully ported Intake manifold casting 12552138.
-AS&M 58mm Throttle body.
-Ford Racing SVO 30 Lbs. Injectors.
-Camshaft:223/230 .565/.565 112 LSA( old setup Sept 2012 )
-New camshaft:228/236 .576/.572 110 LSA( Oct. 2012 )
-Fel Pro 1074 head gaskets .039".
-Fel Pro 1284 intake gaskets.
-Autolite #104 0.030".
-Hypertech 160 degree thermostat.
-MSD 83811 Pro-Billet Distributor.
-MSD 8226 Blaster coil.
-MSD 32149 8.5mm Spark plug wires.
-TPIS High flow mass air sensor housing.
-Meziere WP118HD Electric Water Pump.
-Shortblock :
-385CI ( 6.3L ) LT1 4 Bolt main Corvette shortblock.
-Scat 9000 stroked lightweight forged crank.
-Scat forged rods.
-Bored .040" over.
-Forged Pistons -5cc dish.
-4045MS-15 .040" + .005" Mahle rings file to fit.
-Rings gap : 1st .018" , 2nd .020".
-ARP main studs.
-Melling 10555 High Volume Oil pump.
-Clevite 77 MS-909H STD bearings crank Bearings.
-Clevite 77 CB-663H STD Connecting rods bearings.
-12370835 GM single roller extreme duty timing chain set.
-Fluidampr Harmonic balancer # 740101.
-Balanced and Blueprinted.
My motor built thread back in 2010 ..here.. .
I think my cut off is set at 6300RPM but I have the shift light set at 5800RPM so I may have a few times hit the rev limiter but nothing that will hurt the motor.
To be honest I don't know if the valves floats or not at high RPM.
Still don't know what will be the damage under the head ( piston , etc. )
I should find out later this month.
They seem to have some sort of major QC issue building IN RECENT YEARS.
In this other case I know of the nitriding alone should have extended spring life. If you repeatedly get similar life out of springs you know that it is just the limit of that valvetrain combination, when you buy the "same" part or an upgraded nitrided version of that same part and life drops dramatically this is a QC problem.
Here's the spring that broke earlier this summer on the right side bank ( no internal damage ) .
( It's in 3 pieces because I had to cut it with a die grinder since I was unable to grab it with a spring compressor tool ).
This is a closeup view of the one that broke on Nov. 15 2012 on left side bank .
Funny thing is they both broke about the same place and this with 2 different camshafts specs. 6 month apart.
Left spring in from earlier this summer and the right one broke this Nov.
I have no choice but to pull the motor and transmission out.
This is not what I had in mind for this winter as far as car project .
