Beehive springs Strikes again.(edit) Now called : Engine rebuilt 2013 .
Since I'm not that technical what does mean the above quote exactly ?
I had the heads put together by Lloyd Elliot so I don't think there is anything I should worry about there but does it has something to do with deck height , push rods , cam specification etc. ?
This motor was machined and put together by a local shop here and I think their works is well done too.
I drove about 20,000 KM before 1st faillure .
While proper setup height certainly is important it does NOT explain all instances as we are seeing professionally setup heads break the PAC beehives. Also like I said I saw a second set break at half the mileage, same cam but the second set was nitrided. To me that almost has to be a wire QC issue, for a nitrided spring to break in half the use.
Funny how a false prophet wildly missuses(square lobes) the Comp 918 contributing greatly to the number of failures of those we saw and Comp gets 100% of the blame but then another company has things setup by more competent people and the springs could not possibly be the cause.
On the Comp thing their failure rate had climbed when they switched from PAC as a supplier to someplace in I think South America, there was a genuine problem there but those who had bad cams just wanted to blame Comp no matter what.
I am a lab technician that tests products, mainly appliances, for safety and compliance to all types of standards. These spring failures should be caught in a lab. These companies should have fixtures setup to test these springs, in coil bind, high RPM, high temperature...etc. Either they are not testing these springs right or they are failing in the lab and they just don't care because they are saving money using cheaper grade wire.
I'm not blaming anyone on this failure but PAC Racing has contacted me and they want to have both springs for inspection.
I'm sending them Monday morning.
I think it is important for them to make sure it is not a spring quality issue .
Like other member said maybe it is my setup too so we'll see .
Right now I'm working on pulling motor and transmission out.
Saturday Nov 24th 2012.
Finally a day off at work so I've worked on the car.
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e56213499e00000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e5eb22884300000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e52320882500000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e5f175881900000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e4501c69c400000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e53ca5c83700000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e56654c8eb00000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e54109883d00000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e4bf9529a200000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e45d8da8fb00000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e4876d294600000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e4a2c4e85500000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
![](http://im1.shutterfly.com/media/47a2cf05b3127ccef1e579f988d100000030O00Act3LNk5YuGIPbz4E/cC/f%3D0/ps%3D50/r%3D0/rx%3D950/ry%3D800/)
Next is split transmission and motor to be able to put this last one on the stand.
#32
It's a bit sad that I have to do all that work because of a valve spring .
I had no major plan for this winter and I had no extra money for any kind of modification for this winter.
#39
Have you pulled up any squares after a fluid dump to be sure there isn't nastiness underneath? How do the engine hoist and stands roll on it?
Building this tapped the budget for awhile but I do want to plan for a nicer floor, the sealer the concrete guy put on(without asking) is junk and only going to make it harder for me to recoat it. a floating tile system would be easiest.
![](http://i120.photobucket.com/albums/o165/96capriceMGR/garage/th_SAM_1517.jpg)
That is 28x32 10ft walls and cathedral ceiling so I will have all the lift room I could want if I can ever afford one.
