Coil Pack Relocation
You know it would likely help a lot of you had a signature or some other way mentioned you are doing a LTCC, 24x, or Delteq swap.
Some guys are going to find this confusing since the stock coil works perfectly on the front of the head.
Far as alternatives, if you want the mounted with the engine but not on the VC then on the intake is about the only other option.
