Intense gas odor when heater is on.
http://shbox.com/1/evap_sol.jpg
A temp sensor can definitely cause a host of problems. I had an intermittent cranking issue I was chasing forever and it was that sensor.
If the solenoid is clogged you can blow it out with compressed air. If it has charcoal in it that means you need to replace the canister though.
Joe
