Well i got it.
Going to replace the fuel filter and fuel and see what that yields.
Check wires / new wires
Double check firing order and wire routing
Check fuel pressure new filter is good
Everyone likes to blame opti but first try the basics usually it's something simple
This spring I thought my car was screwed after sitting and the above fixed it.
Good luck!
Hoping any of the old crappy fuel burns off quickly. Might just dump all the fuel that's in there anyway it didn't fire up as smooth the second time. Didn't pull any timing according to the scanmaster either this time. Need to get tires for it and register it still
Also, verify the intake air and coolant temps. Unplugged or open circuits show the PCM -40 deg F. Makes for very rich. Hard to mis-tune one bad enough to put fuel in the oil. Not likely your problem.
Autolite 106 or 104 plugs. Nothing that says NGK.
Never put a high volume oil pump in any SBC. Valve covers full of oil is not what your after. I have had many highly modified SBCs the past 50+ years I have raced. Not seen a single one that needed one. Circle track and drags. Like after market MAFs, if you make and market about anything somebody will buy it. I have yet found a purpose for a high volume in any V8 Chevy.
On Ed's comment about plugs I will say the TR55 that is far and away more recommended I found to be wrong for heads/cam setup, catr actually stalled a few times with the AC on. A swap to Autolite 104 fixed it but I would have been open to the idea of a NGK TR6 just couldn't find them locally as easily.
Long as I am thinking about it water could be a concern too, when the pump is running it might mix it well enough to mask the presence but then letting it rest and settle out might make for a slug of it to hit the motor again on startup.
Not sure what to do besides top off the tank drain it again and see what that yields?
Had it happen once, car needed throttle to stay alive, swapped to a spare and the car idled high that one was froze open too far.
That vac hose is pretty small and plugs into the passenger side of the intake right? I should see no fuel when i cycle the key a few times?Cycling the key only causes the pressure to build after i've had the fuel system hooked back up right? No way that'll dump to much fuel?
Previous owner said he replaced both temp sensors. I have a spare iat laying around and probably a temp sensor too. Just didn't want to take any coolant out
Check your coolant temp reading the PCM "sees" with a scan tool
Check your intake air temp reading the PCM "sees" with a scan tool.
Having to hold the pedal on the floor puts the PCM into Clear Flood Mode ( shuts the injectors off) meaning it is getting WAY too much fuel for some reason. Don't put any more fuel filters on it! Clogged filter would cause a LACK of fuel. Not your problem if you have to hold it on the floor to start it.
If your spark plugs are black (I'm guessing they are) it will soon stop starting at all until cleaned or replaced whether you fis it or not.
Good luck!
Hoping the plugs will suffice to get it started again.
