lt1 top end
Old Dec 9, 2012 | 08:28 PM
piotrekusa's Avatar
Default lt1 top end
Hi everyone
I just got a 95 camaro z28 A4.I wanna do some mods:
-CC503 cam
-Scorpion perf. 1.6 RR , 3/8 self aligning
-Trick Flow springs (TFS-16918-16) ???
-CC magnum pushrods 5/16" , 7.200 "
-CC steal retainers (7 degree) along with locks
-52 mm TB
-CAI
-Long tubes,no cat,? on muffler
-Port and polish intake and heads
Just wanna make sure all these parts will work together.Also really like an idea of making sts turbo for this car my self.I know that i gotta do the transmittion and rear end first.The question is, will this setup be good for low boost (5lbs) turbo?
Thx,Peter
Old Dec 9, 2012 | 09:29 PM
96capricemgr's Avatar
I would jump right to 7/16" studs guideplates and rockers so you have all you need for about any hydraulic cam setup.
Pushrods should be measured for.
For a 52mm TB I would ONLY do a rebored stocker, if you are going to the hassles of making an aftermarket work right just do the 58mm, no downside to the extra size.
"port and polish" can mean anything from a local shop ruining a pair of castings to someone who knows what they are doing making them better than most aftermarket stuff or anything in between. CHOOSE CAREFULLY HERE!
You will need a stall, really should do gears and some suspension work, maybe a fuel pump and probably need some 30lbs injectors.
You are heading into this backwards, you have a lot to do before a car is ready for heads/cam.
Old Dec 9, 2012 | 09:43 PM
piotrekusa's Avatar
Thanks for the info.I was just thinking of injectors and fuel pump.Also pcm tune.I know that i need a stall but don't know which one.Its gonna be DD car.
Old Dec 9, 2012 | 09:52 PM
great421's Avatar
One MORE upgrade required for a turbo:
Mr. Gasket MLS head gaskets and ARP studs.
I guess that's two more upgrades...
Old Dec 9, 2012 | 10:17 PM
piotrekusa's Avatar
Good to know.Now,what about headers?if I go with the turbo,go with long tubes or stick with the factory manifolds?
Old Dec 9, 2012 | 10:53 PM
You need to decide on the turbo or not before you decide on head work, cam and exhaust.
If you are going to do a turbo I would not bother with headers and I would choose a different cam. Depending on what gears you have a turbo might be OK with stock gears.
Old Dec 10, 2012 | 10:30 AM
piotrekusa's Avatar
Well,the turbo was only an idea.Frankly speaking I'm not sure about it.
Why is it better to keep oryginal headers in order to have a turbo?
Thx
Old Dec 10, 2012 | 03:51 PM
Longtubes, even coated will just shed heat letting the exhaust gasses condense, really not a good thing when you are trying to get that exhaust gas volume to turn the turbo.
Like I said though an otherwise stock car needs a lot of other mods before heads and cam become reasonable next steps.
Old Dec 10, 2012 | 04:28 PM
piotrekusa's Avatar
I think im gonna pass on the turbo.
What do u think about valve springs that I wanna get,are they good enough?
Old Dec 10, 2012 | 09:28 PM
piotrekusa's Avatar
Any body?
Old Dec 10, 2012 | 11:15 PM
BOOSTED AFR's Avatar
Those springs appear to be plenty stout. At the correct installed height I believe those springs would even control an upgraded camshaft if you decide on that route later on.
Old Dec 11, 2012 | 07:29 AM
piotrekusa's Avatar
Nice,thanks
Old Dec 11, 2012 | 10:09 PM
rich5368's Avatar
I suggest read read read. Try not to jump in to fast and skip other things or you're going to be disappointed with results. I recommend starting with boltons. A stall and gears and tires I feel are probably your biggest bang for the buck as far as getting off the line. Just my 2 cents
Old Dec 11, 2012 | 10:50 PM
piotrekusa's Avatar
True,I'm just not sure i understand how the stall will make a difference
Old Dec 11, 2012 | 11:29 PM
fex77k's Avatar
A good stall matched to your top and rear end makes a world of difference.
Old Dec 12, 2012 | 06:50 AM
Then put off all the engine plans till at least spring. If you don't understand how a stall is critical to make what you propose work then you are just going to do things wrong and create frustration for yourself.
Trust me I did a mild cam before the rest of the boltons, and I am telling you I screwed up. The cam I did was much milder even and it didn't really help the car till I put a good torque converter in.
Old Dec 12, 2012 | 10:45 AM
bowtienut's Avatar
Ditto!
Originally Posted by 96capricemgr
Then put off all the engine plans till at least spring. If you don't understand how a stall is critical to make what you propose work then you are just going to do things wrong and create frustration for yourself....
Ditto!
A good converter will make more of a difference in the car's performance than all of those mods you mentioned in your first post combined.
I'm not saying don't do them, but if they're worth X without the converter, they'll be worth 3X with it. The only things I'd do before the converter is exhaust and gears.
Old Dec 12, 2012 | 12:49 PM
To elaborate more I modded my car backwards I did a cam before headers/stall or gears. Gained little to nothing at the track, now "normal" gains from a performance converter on a mild bolton car are at least .4, when I gave mine a stall it gained closer to .8, a swap from 2.93 to just 3.42 was another .2 and then the headers were like .7.
Now keep in mind I have a Caprice, the 208/221 .474/.510 cam I had was mild drove perfectly with the stock stall and gears but like that went a single best of 14.9 (cam/catback/tune modified stock intake tract) the mild 2800 stall dropped it to 14.1, the gears 13.9ish and then headers 13.2 I did put some slicks on in that time too but at 14.9 traction was not any sort of issue.
You are going with a much larger cam that would "need" the stall increase even more, you should be going with 3.73 gears or even 4.10s and at least a 3200stall. Stock stall, stock gears I would expect the car to slowdown badly to 330ft mark, little quicker at high rpm but being slower down low will hurt more than you gain up high.
Old Dec 12, 2012 | 07:17 PM
piotrekusa's Avatar
Good info,that's what I like.i know I will learn a lot on this forum.
Now I know I need a stall and gears which I'm gonna get before the engines done.could somone still explain what diffrents ill feel driving the car with diffrent than original stall?
Old Dec 12, 2012 | 07:59 PM
I would say try and attend a gathering of some sort and get a ride in a few cars.
