LT1 Vette/Fbod
Old Dec 10, 2012 | 08:03 AM
01Z0H6's Avatar
Default LT1 Vette/Fbod
So, i recently purchased a 97 SS... Heads are off, motor has 140K on the odo.. Found a low mileage LT1 out of a 95 C4 Corvette... I know it will bolt right in... Question is, will my harness work with it. LMK your experiences, results.
Old Dec 10, 2012 | 09:16 AM
RamAir95TA's Avatar
It really depends on what you're swapping over. But overall there won't be any major problems.
Old Dec 10, 2012 | 09:25 AM
BOOSTED AFR's Avatar
He'll need the crank reluctor and timing cover from the 97 engine swapped to his 95 if he wants to keep the misfire detection and he'll need the crank hub and balancer from the F Body as well to make his accessories operate properly, correct? Also, the original water pump needs to be used as F and Y body heater/coolant hoses have slightly different routing.
But yes, as RamAir said, none of these issues are a big deal.
Old Dec 10, 2012 | 09:49 AM
djjab57's Avatar
Damn is that the motor I seen for $500 ? I was going to get it but couldnt find it again
