Help convert a lt1 94 to 95 camaro
Old Dec 11, 2012 | 07:44 AM
Adam1203's Avatar
Default Help convert a lt1 94 to 95 camaro
I have a 94 lt1 I need to steal from another project to get my 95 camaro up and running. Right now its just a long block with an opti. Can I know the 94 timing chain cover and opti is different. every thing else I can move over from the 95 engine. I also know the 94 opti is slightly different vent wise and I believe the cap uses a different harness. Is there anyway I can make the 94 opti work with my 95 harness? can I use a 94 harness extension to the main harness? and if so will the pin out be exactly the same?
Old Dec 11, 2012 | 08:23 AM
RamAir95TA's Avatar
Just use the readily available harness extension and you're good to go.
