nitrous help
Old Dec 12, 2012 | 05:18 PM
ballas03's Avatar
Default nitrous help
I brought a used nitrous kit made by Harris speed works. The person before me put dual nozzles and i dont know how to jet it. it is a wet kit and he put a Y fitting at the solenoids. the calculators all only do single nozzle. i was told you divide the jets in half you would use for single so i calculated a 75 shot and for the dual nozzle set up i have i put a 12 fuel and 20 nitrous is this right and do you just cut the jetting in half.
Old Dec 12, 2012 | 05:37 PM
93 LT1 Vette's Avatar
In a short answer yes. Two .020 nitrous jets fed by the same bottle equal the same amount of N20 forced into the motor, as one .040 jet fed by the same bottle. Two .020 would produce closer to 60rwhp.
Old Dec 12, 2012 | 05:53 PM
ballas03's Avatar
Thanks alot i tried calling all the nitrous makers and couldn't get a definite answer. also do you think i should go smaller on the fuel jet the the online calculators are saying.
Old Dec 12, 2012 | 06:07 PM
BOOSTED AFR's Avatar
I was under the impression that through a round orifice, the ratio of flow is determined by the square of the diameter ratio.
Thus a .40 would not flow 2x what a .20 would, it would in fact flow 4x as much.
This is derived from an elementary understanding of geometry. When the radius of a round object is changed its area is changed by that factor squared.
A=π*r^2
Old Dec 12, 2012 | 06:25 PM
Call Nitro Daves they will hook you up. I would start fat and lean it out. Each setup is different. 125hp shot with a good AFR equaled a .057N and .035F for me which was way fat by the charts. As far as V=2xdia3 or whatever, I have no idea 2x.020= 1x.040 as far as I could find on the Bullet and other N20 forums. Personally I would shitcan the Y's and run one, less stuff to leak. Not much to be gained as far as distribution in a 4 inch tube only inches from the TB.
Old Dec 12, 2012 | 08:12 PM
bowtienut's Avatar
A=π*r^2
Yes, thank you. And in fact it's even a little more than 4X when you compare the area vs. wetted perimeter of the two setups.
93 LT1 Vette, I agree with you that it makes no sense to run dual nozzles in his case. Always go by the "KISS" principle
Old Dec 12, 2012 | 08:41 PM
thanks for the confirmation!!
A little mistake on nitrous jetting for OP could end up causing a big dent in a bank account!!
Old Dec 13, 2012 | 07:48 AM
ballas03's Avatar
I think i am going to get rid of the second nozzle. If so where should i put the nozzle and i will the be able to use the online calculators right?
