lt1 swap no start
I finished everything up went to start it just cranks n cranks. I checked the fuel pressure its got pressure up top. So i checked for spark i got Nothing dam im pissed at this point...
Checked no 1 plug no spark.. checked the coil nothing.. what can be wrong? I dont have a ground on the battery to body can that be n issusr? How do i start to fix this issuse? Let me kno thankx
Secondly is the ground needed for the battery to body? my harness didnt have a second ground from the harness only connects to the battery.
Third how do i check to see if the icm n coil get signal from the pcm? Do i disconnect the opti side of the plug wire n put a spark plug there to see if i get spark from the coil?
follow this step by step, also check the terminals on both sides of the opti connector, they are known to get corroded.
Did you replace the opti? if you did, are you sure you installed it properly? If you have a cam-dowel driven opti it can easily be installed incorrectly.
Im going through the same thing with my swap so ive done all of this multiple times, lol
Before my saints game for some reason i wanted to take off the optispark! So i did just that i took off the water pump. So i started lookin over the opti harness, i pulled it out cause i seen the wires looked cracked n stuff, so i took it out i be damned rust on the end of it.. so i pulled the optispark out i turned it upside down rusty water came out i was lke dam.. so now i gotta wait till friday to get a new one.. any body had any luck with chandlers opitspark? I kno i kno im kinda broke this week.. i need my car
