audio alarm module
Old Dec 17, 2012 | 12:59 PM
Meen95z's Avatar
Default audio alarm module
Anyone have knowledge of the audio alarm module on 95' fbody's? Its the brown box next to the horn relay and flasher relay. Have 2 wires both black with white stripe not hooked up. Not sure if they are important?
Old Dec 17, 2012 | 02:00 PM
shbox's Avatar
The module just plugs in and has no external wiring that I am aware of. Perhaps the two wires are your VATS wires? Any VATS bypassing done?
Old Dec 17, 2012 | 02:58 PM
Meen95z's Avatar
No bypass done. I have the dash out and was taking out some wires I dont need to clean it up some. First thing I thought was it might affect my radio working. I traced the 2 black wires with the stripe to the backside of where that plugs in. I cannot find a schematic either with that in it. I almost looks like they was not hooked up all along but wanna make sure before I put it back together.
Old Dec 17, 2012 | 02:59 PM
Meen95z's Avatar
Also I have tunercats and turned vats off, and i do get a security light, but doesnt affect anything.
Old Dec 17, 2012 | 09:43 PM
shbox's Avatar
Yeah, the computer tuning won't have any effect on the lamp. If the VATS module is still there, you can do the resistor bypass to turn it off or just remove the bulb from the dash.
Old Dec 17, 2012 | 11:38 PM
Meen95z's Avatar
Alright, do you know what that audio alarm module does or is there a diagram for the wiring anywhere do you know?
Old Dec 18, 2012 | 06:57 AM
shbox's Avatar
I've not seen a schematic for the module, itself, but AFAIK it is basically just a speaker for the chimes you hear.
Old Dec 18, 2012 | 04:41 PM
Meen95z's Avatar
Alright, doesnt sound critical, thanks!!
