Intake manifold gasket.
Old Dec 20, 2012 | 04:16 PM
jasonz28camaro's Avatar
Default Intake manifold gasket.
I got some oil that looks to be coming out of one of my intake bolts or between the head and intake in that area. I'm assuming the gasket busted from boost, #15. What is the best intake gasket for boost and what special things need to be done like sealant around the runners?
Thanks. See my sig for car info
Old Dec 20, 2012 | 04:38 PM
fex77k's Avatar
I put sealant on the treads that touch oil and paint a shellac around the intake ports. Works for me.
Old Dec 20, 2012 | 04:41 PM
I might just try to put sealant on that one?
Old Dec 20, 2012 | 04:44 PM
fex77k's Avatar
Real thin coat and don't over tighten the intake bolts.
Old Dec 20, 2012 | 05:23 PM
Z8'S's Avatar
I use 3m weather stripe adhesive. put it on both sides of gasket and on the head and intake, seals anything!
Old Dec 20, 2012 | 05:27 PM
I had a different washer on the leaking one. Turns out that the sealant on that one was not doing its job that well. It was only in the head about 1/4" at the most, had indifferent washer on it that didn't allow it to go in all the way. Got a longer bolt and put some sealant on it. If it doesn't hold I'll pull the manifold.
Old Dec 20, 2012 | 10:20 PM
fex77k's Avatar
That works great on freeze plugs too.
Old Dec 20, 2012 | 10:29 PM
dont get me started on freeze plugs lol
