Extreme Vibration
I'm getting a terrible vibration in my car. I just finished doing the head gaskets and opti about 2 weeks ago. It happens at about 3k rpms and above. Pushing the clutch in doesn't affect it. What do you guys think?
I read that it might be a bad harmonic balancer. I did have it off to change the opti.. is it possible to put it back on wrong? I'll be messing with it tomorrow to see if I find anything. It feels like I'm riding down the street in an old coin operated dryer.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
You said pushing the clutch in doesn't change anything.. Hmmm try turning off the engine while in neutral and coasting if it goes away could be simple flat spots on your tires from sitting. Warning/disclaimer I do not recommend doing such act on a public road to diagnose or treat any mechanical issues with a veh.
I had the tires rotated and balanced two days ago. The car only sat for about 5 weeks.
It's a really really bad rattle though. Like riding a jackhammer through traffic.
The only time I ever experienced this type of rattle was merging into the emergency lane on the highway and going over those strips that are in the pavement to wake people up.
Figured I would bring this back up instead of starting a new thread.
I still have this terrible vibration. It's only at higher rpms. Happens moving or stationary, clutch in or out, even with the serpentine belt off.
The car runs and pulls great except for high rpms. The only things I can think of at this point are messed up internals? When I had my heads machined the guy at the machine shop replaced one valve spring that was broken. I've read that they should be replaced in sets. Could this be a problem as well?
Lost on this one.
Lost on this one.
