Weight reduction lb/hp
Old Dec 28, 2012 | 12:50 PM
fex77k's Avatar
I run an 8" converter for just that reason.
Old Dec 28, 2012 | 01:05 PM
96capricemgr's Avatar
An 8" is great if you need a stall over 4200ish and don't care about lockup. For most of us with street/strip cars though a 9.5" somewhere between 3000-4000 stall with lockup is a more reasonable choice for when we are on the street.
A couple friends have 8"ATI in "street" cars one in a TH350(with a lot of fancy light internals) the other a TH400 Gear Vendor setup. I personally wouldn't be happy with either as a street car but everyone's tolerances are different. Those guys started playing with cars that had 3 speed trannies so they don't miss lockup and OD. I started with my current car so lockup and OD are what are normal to me and I would miss them.
Old Dec 28, 2012 | 01:29 PM
Hit em Up's Avatar
Now were you planning on spraying that 200 or so shot on this same 8"converter? Charlie at ATI said I would have to run there 9"fuel and blown if I wanted to run any amount of spray! Our combos are pretty similar that's why I ask.
Old Dec 28, 2012 | 02:28 PM
quik95lt1's Avatar
got one from coan on the shopping list for this winter
Old Dec 28, 2012 | 06:48 PM
mdacton's Avatar
charlie told me the same thing once so I tried it anyway, converter loved it!
You just need to try it
Old Dec 28, 2012 | 07:40 PM
noice's Avatar
To be honest I don't really listen to what companies suggest that often, that car that Fex77k is talking about is only 2100 lbs so is isn't really comparable to your car weight. Also I've seen 8" converters behind BBC combos that were using 25% Nitro 75% Alcohol and using nitrous on the line.
I listen to people that actually run the items that I use versus the companies that sell it.
Old Dec 28, 2012 | 08:48 PM
TwoFast4Lv's Avatar
I had A-1 do mine and they nailed it out of the gate!
Old Dec 28, 2012 | 09:56 PM
Hit em Up's Avatar
Point taken! Now I have also seen BBC run the converter dry on 8"-9" converters to due to not housing enough fluid.That's why I felt I needed a 9"with a 300shot.I really want closest to best of both worlds as possible lol.sorry for getting off track op!
Old Dec 29, 2012 | 02:06 AM
fex77k's Avatar
That's why i have to stay of the trans brake, usually no longer than 3-5 seconds at the line. I do not run a cooler, just a deep pan with a hardline loop.
Old Dec 31, 2012 | 07:45 AM
quik95lt1's Avatar
ati also told me that it was OK to neutral my th350 after i cross the stripe..........safe to say you cant it will cause the drum to spin about 25000rpm in my car and will create a grenade..........was concerning to hear that false safety from them, if i hadn't known what would happen and did it we couldve had a very interesting set of pictures to look at
Old Dec 31, 2012 | 10:21 AM
Hit em Up's Avatar
Yeah I would say that's concerning lol!! Can't see how that would be a good idea? Btw do you still have trans and converter for sale? My friend is in the market for one and I believe your stall is inline of what he needs.
Old Dec 31, 2012 | 11:51 AM
  #32
BIGCAT7274's Avatar
just adding.
in the trans is setup with a clean neutral you can do it. but the safest is let it gear down in high till you hit the turn out.
Old Dec 31, 2012 | 12:13 PM
  #33
quik95lt1's Avatar
i sure do wont be out till feb or march but its still in the car
Originally Posted by BIGCAT7274
just adding.
im building one of those now coan makes a special valvebody and input drum to allow you to do it car will shift PRN123N PPP makes the shifter
Old Dec 31, 2012 | 03:04 PM
  #34
BIGCAT7274's Avatar
ppp is the ****.
Old Jan 4, 2013 | 06:21 PM
  #35
noice's Avatar
You would have got a TH350 lap dance. Probably would have cost you just the tip.
Old Jan 9, 2013 | 08:23 AM
  #36
jrwilliams95z28's Avatar
ive heard 100lb for .1 seconds and 8hp. odviously thats a not scientific.
Old Jan 9, 2013 | 09:04 AM
  #37
Ed Wright's Avatar
9-Second Club
As pointed out, 100 lbs is worth a tenth only for slower cars. Like usually 13 second or slower.
Clean neutral is the way to go, especially if your over 7000 at the finish line. Rossler, Coan and Pro Trans all make clean neutral T350s, probably others. Btw, the shifter in that pic is the best there is, but the one for a clean neutral Trans has another "N" past the "3" position.
I tried an A1 converter, cost me over a tenth. Marv Ripes sold it several years ago and has now retired. They bought it back, as they told me they would. Good guys.
Have not tested a Coan. Good friend here locally, that I travel & pit with, has two fast SS cars. (1 for each son that drives them) who always used ATI had Coan build one of their light weight T350s for one car. Tried one of their converters too. Took three tweaks to make it as fast as their ATIs. Did work with them until they got it thought. Good guys also.
I have told this before: If Charlie Plott at ATI told me a **** ant could pull a freight train I would start figuring out how to hook that little sucker up.
I noticed the majority of NHRA SS cars had ATI converters, figured I could not go too wrong with them. Glad I did.
Old Jan 9, 2013 | 09:18 AM
  #38
quik95lt1's Avatar
yep ive heard the same ed that PPP shifter is supose to be the ****.....i had to go clean neutral, winding my motor down from an 8krpm trap every pass would not be good........im between ATI and Coan on the converter right now its still a toss up but ive got time to decide....waiting on payment from a board member on my 4l60e so i can buy the hard parts for the th350.......tell u the truth im sad to see this thing go lol
Old Jan 9, 2013 | 12:10 PM
  #39
Ed Wright's Avatar
9-Second Club
After what myself and other racers I know and work with have seen, I would buy the ATI and be done with it.
Old Jan 9, 2013 | 12:37 PM
  #40
bowtienut's Avatar
I agree. I thought that's what I told you to do a YEAR ago, Mike!
Even though the ATI in my car was a hand-me-down and not purposely built for it, I tried two others of another brand that WERE built specifically for it and failed to better its performance.
