Installing ATI BB Hub onto crank. Last 1/8" halp
I needed to replace my opti and I have the ATI BB outer diameter hub and so the opti would not clear it and come off. I bought the kent-moore tool and backed the hub every so slightly off the crank (maybe 1/8") and then took the old opti off and put the new one on.
Now I am trying to press the hub all the way back on and the tool won't work. The big washer and bearing supplied with the kit don't press against the hub like the picture shows, the inner hole in the hub is big enough where the washer and bearing just bottom out. So I don't have anything pushing on the hub.
![](http://shbox.com/1/crankshaftremover5%20copy.jpg)
8 Second 6 Speed Director
Location: windsor, ont. canada - Home of the fastest LT1 6spd.
1 Post
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
wow, how much was that tool!
anyhow, my .02 is make your own tool.
all you need is some good threaded rod. a couple of grade 8 nuts, some fender washers and a large enough piece of steel to drill a hole into so that it pushes on the hub. lemme see if I can take a pic of mine to show you what i mean.
any old removal tool should work as long as you have the correct bolts for it.
I bought a piece of all-thread (dont recall the correct size), cut it to about 5" in length, threaded it into the crank all of the way (for MAX strength) then used a pair of stacked nuts and a washer to run the hub on. Cost less than $5 and poses zero risk to the threads in the crank. I would never EVER consider using the bolt for fear of damaging the crank threads when the best way is so cheap, quick and again, poses zero risk.
