Cam & gear vs Converter & gear, which one
Hey guys buddy of mine has a 1997 z28 a4, with some bolt on such as longtubes, ewp, intake, 58mm or something TB, full O/R exhaust. now here is my question for you guys in his price range he could do 1 of the following
1. lt4 hot cam, and some 4.10's
OR
2. do a 2400-2800 stall, and 4.10's
He does not want a bigger stall even tho i told him with bolt on's he could do a 3600, but he wants to keep it under 3k range. Which would be a bigger performance gain do you guys think.
My vote would and is a 3600 stall with some gear and tire but he will not go above 2800 stall thanks guys!!
OR
3000 stall, I would recommend and 3.73 gears not 4.10, he would get bored of the lt4 cam and eventually will want bigger and will need 1.6 rr and others,etc
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
Explore gear/mph info here:
www.f-body.org/gears
With a auto I would say stall and gears but plan the parts ahead for a cam later. The hotcam really woke up my car but I already had gears and am a M6. With the LT4 springs I was getting some valve float at 6k or so, I wouldn't recommend them for the hotcam. IMO GM messed up on that one.
A 3800 stall converter with 3.73 to 4.10 gears will give more gains than cam and gear.
A LT4 stick is not the best option and most people end buying a bigger one. I think is better to buy proper gear and stall then save for a good cam, springs and maybe rockers, and a good tune of course
