TURBO LT1 winter build, tons of pics inside!!
Hey fellas, well this thing is getting closer and closer to being done, trying to go mid 9's this year on the 6 speed (@9000 ft)
last year with a stock bottom end and some ported lt4 casting and a custom hyd roller on 9 psi it went 11.86 @ 120 on bald street radials and a clutch rated to 450hp (600rwhp on 9 psi) full street trim with spare tire and jack still in the trunk.
the interior is staying intact but no more spare and jack lol not doing too much weight reduction. front and rear supports are gone already.
heres what she has/is getting:
Engine:
386 incher 4.045x3.75
lt1 block 4 bolt splayed caps arp studs all around
lunati pro crank
crower 6" billet I beams
diamond pistons
TFS twisted wedge heads max effort port 2.100/1.625 valves
victor single plane
102mm TB
wilson elbow
comp custom grind 255 260 114 .680 .692
isky ultra light lifters
comp P rods 3/8 tapered
comp ultra light 1.52 rockers
k motion springs and titanium retainers
comp timing set
melling billet pump
moroso pan
Turbo system:
custom 1.75 primary forward headers
3" crossover
currently running a single gt4202 (moving to a gt4508)
4" down pipe out the front
60mm gate
twin 50mm bov's
custom W2A IC
3.5" Ic piping
wiggins clamps
drivetrain:
stock t56 with billet forks
mcleod race twin disc
mark williams 9"
Ford motorsports forged 3.25 gears
mark williams aluminum center section
moser full spool
moser 31 spline axles
carbon drive shaft
Suspension/Brakes:
custom torque arm with adjustable arm mount on 9" housing
BMR lower arms
BMR relo brackets
BMR panhard
BMR tubular k member
stock front a arms
custom sube frame connectors that tie into both DS safety hoops
90/10 front struts
50/50 rear shocks
baer claw front brake system
14" front rotors
11" rear rotors
jegs manual brake master
Fuel system:
weldon single pump
-10 feed
-6 return
Aero regulator
Aero rails
Aero filter
160# injectors
heres some pics of the progress, motor pics will be up soon!
![TURBO LT1 winter build, tons of pics inside!!-67428_523704370983558_1611529057_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389864d1469569506t-turbo-lt1-winter-build-tons-pics-inside-67428_523704370983558_1611529057_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-321357_523704450983550_1053363871_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389865d1469569506t-turbo-lt1-winter-build-tons-pics-inside-321357_523704450983550_1053363871_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-603120_523704734316855_729381747_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389866d1469569506t-turbo-lt1-winter-build-tons-pics-inside-603120_523704734316855_729381747_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-530850_523704580983537_540656402_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389867d1469569506t-turbo-lt1-winter-build-tons-pics-inside-530850_523704580983537_540656402_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-64237_523704764316852_1674160506_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389868d1469569506t-turbo-lt1-winter-build-tons-pics-inside-64237_523704764316852_1674160506_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-150960_523704424316886_493588242_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389869d1469569506t-turbo-lt1-winter-build-tons-pics-inside-150960_523704424316886_493588242_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-483046_523704744316854_912481739_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389870d1469569506t-turbo-lt1-winter-build-tons-pics-inside-483046_523704744316854_912481739_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-530591_523704597650202_735689697_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389871d1469569506t-turbo-lt1-winter-build-tons-pics-inside-530591_523704597650202_735689697_n.jpg)
![TURBO LT1 winter build, tons of pics inside!!-542275_523704280983567_2112789633_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389872d1469569506t-turbo-lt1-winter-build-tons-pics-inside-542275_523704280983567_2112789633_n.jpg)
Engine:
lunati pro crank
diamond pistons
victor single plane
102mm TB
wilson elbow
comp timing set
melling billet pump
moroso pan
Turbo system:
3" crossover
60mm gate
twin 50mm bov's
custom W2A IC
3.5" Ic piping
wiggins clamps
drivetrain:
mark williams 9"
moser full spool
carbon drive shaft
Suspension/Brakes:
BMR lower arms
BMR relo brackets
BMR panhard
stock front a arms
90/10 front struts
50/50 rear shocks
14" front rotors
11" rear rotors
Fuel system:
weldon single pump
-10 feed
-6 return
Aero regulator
Aero rails
Aero filter
160# injectors
![TURBO LT1 winter build, tons of pics inside!!-205726_523704297650232_1266894790_n.jpg](https://ls1tech.com/forums/attachments/lt1-lt4-modifications/389873d1469569506t-turbo-lt1-winter-build-tons-pics-inside-205726_523704297650232_1266894790_n.jpg)
yea they were laying around so i used em to cover up the heads, i wont be using those, i have some fabricated aluminum ones when the motor goes in, the motor in the pics is a mock up motor, just a block with my heads bolted to it.
Subscribed, totally badass build and you should run alot faster than 9's with your setup. I'm in the process of doing a turbo build myself, so I'll be following your build closely. Are your injectors high impedence and why 160#'s also what are you using for engine management? What rear gear are you running with your 6 spd as I'm also using the 6 spd?
That's just too friggin sweet for words!!
Since I know dick about turbo systems what's twin 50mm bov's?
Nevermind. Blow off valves.
yes i will be using high impedence as i will be using the factory obdI efi system lol 160's are what i will need to make the power i want on E85 at this altitude.
i run a 3.25 gear like i was using last year. sorry i didnt post gears that was a smooth move. lol
well after countless attempts to run a 4.5" exhaust under the car with out rattling my head off i said because RACECAR! hahaha its going to be decently loud but thats part of it at this level i guess.
Thanks for the info, I have an S60 rear so the tallest gear I can get is a 3.54 and I'm going to be running pumpgas since E85 isn't readily available in my neck of the woods. I just dropped my engine off at the machineshop today to get some upgrades then comes the boost, also what all did you have done to your T56 to withstand the power?
nice, yea we have about 2 e85 stations around my place then about 10 spread over the metro city so i can usually make it if i need to fill up.
as far as the trans goes nothing but shift forks, its been under 650 rwhp for a while now, wasnt on slicks so we will see how far she gets me, i have a buddy here with a 408 88mm ls trans am 1092rwhp on a bone stock t56 on slicks has gone a best of 10 flat. its been i think a solid year and a half and nothing has gone wrong. i figure ill give it hell and see what happens, but if it breaks, hellooooo turbo 400!
