problem help please
Old Feb 8, 2013 | 04:32 PM
94z28shane's Avatar
Default problem help please
I installed headers last night and now I cant get fire, I broke a oil sending unit off and idk if its causing it not to start or not does anyone know what kind of wire I could have knicked or cut in two...or any other suggestion I also didnt connect the smog controll to the header
Old Feb 8, 2013 | 04:52 PM
RamAir95TA's Avatar
Check your plug wires. You probably have a few switched around.
Old Feb 8, 2013 | 05:00 PM
94z28shane's Avatar
Would that cause it to just crank and crank and crank
Old Feb 8, 2013 | 06:11 PM
F0x Slaughter's Avatar
With just installing headers?
Did you break off the coolant sensor?
I did this when I did my headers.
Old Feb 8, 2013 | 06:41 PM
SS RRR's Avatar
Village Troll
If your headers are the only component you changed out and you are not getting spark then plugs or plug wires could be the problem. You did make sure all wires to the coil and ICM are plugged in?
Old Feb 8, 2013 | 08:27 PM
bufmatmuslepants's Avatar
Easiest way to check for spark is ground a plug electrode on something metal and look for the spark. I agree with check all your plug wires.
