Heater sux and low coolant light barely visable
5.7LT1 Automatic. Runs good doesn't overheat or anything but the low coolant light is on but just barely, and my heat sucks terribly it gets lukewarm but thats about it. I live in PA in the mountains so this is quite shitty. hell i went for about a half hour ride and i still had Frost on the window!! Also I turn on the Rear Defrost and it either does nothing or comes on for about 30 sec and shuts back off? WTF
The flush worked on my car for a day. Another member recently had the same experience on here. Best thing would be to just replace it now and only dig into it once.
If your coolant is topped off properly you can ignore the light or unplug the sensor. Don't think I've had a f body with one plugged in
I changed one out on my 86 and it was a super pain in the ***. how bad are they in the newer ones?
Disconnect your two coolant hoses that enter and exit the H/Core, use a funnel attached to one of the hoses, and fill the H/Core with radiator flush - undiluted. Let it stand for an hour in the core, then flush it out with H20 - it worked for me!
Good luck!
+1 to the rear defroster relay
Good to know about the relay for the defroster though. I wondered why that kept switching off...
Make sure you don't have a stuck open t-stat. That will cause low heat.
