Long Tube Headers
Old Feb 15, 2013 | 04:08 PM
NewOrleansLT1's Avatar
Default Long Tube Headers
So I finally ditched the mid tubes for the long tubes, but when I got the car tuned it had the mids. So my question is will the PCM compensate for that extra little airflow? I know he tuned it with a 13.00 afr so that's what had me wondering if the extra air flow will lean it out or??
Old Feb 15, 2013 | 06:12 PM
Ed Wright's Avatar
9-Second Club
The MAF will compensate some. May be enough. A speed density car would lean out. You may very well be fine.
Old Feb 15, 2013 | 06:21 PM
Thanks Ed..
Old Feb 15, 2013 | 06:29 PM
MMWS6's Avatar
Most tuners will give you a wicked deal for a small adjustment like you need. I would be contacting your tuner and see what they would be willing to do. All you need is a little adjustment to your fueling tables and maybe an adjustment to your timing tables. Even just a quick WOT run with a WB, just to touch it up
Old Feb 15, 2013 | 06:45 PM
I guess I'll have to pay for a touch up..
Old Feb 15, 2013 | 06:48 PM
Ed Wright's Avatar
9-Second Club
There is no reason to change the spark advance for longer header tubes. LOL
I have dyno tested several like this, some may lean slightly, many are fine. Odds it's OK are better than 50-50. The MAF "sees" the added air flow, and if everything is OK more often than not it's still OK.
Old Feb 15, 2013 | 07:03 PM
MMWS6's Avatar
You really don't think idle timing would need a little clean up going to long tubes? I would think that his timing is going to drop a little at idle to keep exhaust temps high enough to keep his O2's reacting properly, especially if the engine is cammed?
Old Feb 15, 2013 | 07:07 PM
Ed Wright's Avatar
9-Second Club
Not if it was done correctly the last time.
Old Feb 16, 2013 | 04:49 PM
Ever since I installed the long tubes the car drove a little rough but when I get down on it it's smooth as butter. I thought the PCM had to learn its new environment but it didn't. So I unplugged the o2 sensors and the car drove PERFECT! Why is that? O2 sensors are new. Could it be that their not getting hot enough?
Old Feb 16, 2013 | 07:00 PM
Ed Wright's Avatar
9-Second Club
People do that every day with no issues. What do your fuel trim numbers look like?
Old Feb 16, 2013 | 07:30 PM
I really don't have access to tuning software but I do know that when it was being tuned with the mid headers afr was about 13.00
Old Feb 16, 2013 | 10:43 PM
Ed Wright's Avatar
9-Second Club
That takes a scam tool, not tuning software.
