Turbo LT1 with Opti???
Megasquirt is cost effective specially if you solder it yourself. It is capable of full fuel/spark control. Also keep your Optispark.
The stock PCM uses a 1 bar MAP. You can use a 2 bar but you cut the table in half, killing your resolution.
Anything else I should know or research?
The "guru" on megasquirt right now bar none is denmah. He has put together some outrageous builds with TONS of documentation, with write ups and tons of videos. Search turbo fairmont, his current thread is HUGE in the fi section, called 2500 silverado, but he stayed stock PCM on that build. His name is Matt and he seems to help anyone who asks.
Has the mph to sneak into the 8s at something like 4400lbs but the 8.5" 10-bolt and 4L60E wont take the launch needed.
He uses the OBD2 pcm and a LOT of other stuff every kid wanting half the HP will tell you can't work.
Anybody see any problems running the Clearance Sale Opti Summit Racing has for a turbo build? Im needing one so Im thinking on grabbing a couple.
Thanks for all of the help everyone. I need to read up and will get back if I have questions or comments.
