LT1 rear intake oil leak - My experience
Good point, that should always be done when using RTV.
Few tips I follow and have not had any leaks after are:
1. Beyond cleaning all the old gasket material & RTV off, wipe block & intake mating surfaces liberally with acetone
2. Use FelPro "printo" type intake gaskets
3. Use Permatex Black Ultra RTV 3/8" bead across front & rear china walls that go up onto the heads 1". Let RTV skim over for about 15 min
4. have threaded studs about 3" long installed front & rear hole on one side of the block. You use these short studs to line up intake and drop it dead nuts in place. Remove the 2 short studs and install the intake bolts. Pieces of wood dowel would also work as guides.
5. Torque intake bolts per FSM order/TQ
Smearing is a faulty install technique. If done correctly you should be able to "read the squish" and know its right. It will almost look like a good weld, perfect continuity and evenness with no dripping excess or burst air pockets.
Can't say I concur with that method. The "skin" cannot bond with the surface as well as it does fluid.
Well I can tell you that from the engines I have built for years and years, big blocks, small blocks, I have used this method and have Never, had a leak, where as I have seen Many where they installed the RTV then immediately installed the intake and later had a leak due to a void, or where it dripped into the valley..
If the skin cannot bond with the surface then hows does gaskets bond? they are dry not fluid like material...
I can agree with a fellow Jackstandicandian as well as moe that cure time is crucial before returning to service.
Moe, if you remember the days of "the great wall of silicone", true you had no choice but to let it skin. The gaps on an LT1 though, being ~1/4 inch....Oh, and that's why were having a discussion about silicone...cause the gasket didn't bond
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
Village Troll ![](http://jameskellock.tripod.com/sitebuildercontent/sitebuilderpictures/rsman.jpg)
Just, whomever reads this who is doing research, if you see posts which state it's a good idea to dimple the block or take sand paper and "scuff up" the intake/block surfaces for sealant to "bond more betters..." and to keep the sealant in place, don't read any further. All you are doing is adding channels for oil to get through and out. Leave the surfaces the way they are. There is enough rough material already there for the sealant to bond just fine.
