Taking engine off stand?
Old Feb 27, 2013 | 09:51 AM
lt1_2buku's Avatar
Default Taking engine off stand?
Where are you guys hooking up the chain to move the engine from the stand to K member? I thought I saw a thread that suggested the alt bracket bolt and a bolt on the back of the head. I wanted to read it again to make sure but now can't find any threads on where to hook up the chain other than using the happy hooker.
Old Feb 27, 2013 | 09:54 AM
RamAir95TA's Avatar
If you have a happy hooker, why don't you use that?
In the past I've used a bolt on the front of each head - one in the front and one in the rear.
Old Feb 27, 2013 | 10:00 AM
lt1_2buku's Avatar
Dont have the happy hooker. When I do the search the only hits I get are using the happy hooker.
Old Feb 27, 2013 | 10:21 AM
SS RRR's Avatar
Village Troll
Couple of grade 8 bolts on the front and back of the driver/pass. heads
Old Feb 27, 2013 | 10:53 AM
bufmatmuslepants's Avatar
How'd you get it up there?
Old Feb 27, 2013 | 11:03 AM
lt1_2buku's Avatar
intake and heads where off. I used bolts on the block. A lot heavier and fully assembled on the stand now.
Old Feb 27, 2013 | 12:15 PM
SS RRR's Avatar
Village Troll
Bolts in the heads with a suitable chain will do just fine.
Old Feb 27, 2013 | 01:36 PM
lt1_2buku's Avatar
Ok great, just got back from fastenal with some grade 8 bolts. I'm gonna use the driver front (where the coil bolts to head) and passenger rear (above water crossover)
Old Feb 27, 2013 | 02:45 PM
96capricemgr's Avatar
aint rocket science basically just find two places to get some 3/8" bolts into it, the place you are using is good as are intake to head bolts. I have even seen folks use exhaust manifold boltholes.
On carbed motors they routinely dangle the ending and tranny from the carb flange.
Old Feb 27, 2013 | 06:23 PM
lt1_2buku's Avatar
But this isnt your average lt1.......its a rocket lt1. So yes it is Rocket science.
