How to test injector driver?
Old Mar 28, 2013 | 02:38 PM
teal94z281989's Avatar
Default How to test injector driver?
Hey guys i need to find out my dtc 18 still and its killing me. I looked at all my injector wires they dont look cracked or damaged. Can someone pls help me with my problem.
Old Mar 28, 2013 | 03:38 PM
shbox's Avatar
You should use a meter to check the integrity of the wires. You can also check the resistance of the injectors (should be ~12 ohms). I would suspect something in the PCM last.
Old Mar 28, 2013 | 04:32 PM
all pink wires have 12v, and all injectors have 12.8 ohms. So i pulled my wire harness out and seperated all of the injector wires from the harness to further inspect cracks or slices in the wire and everything looks good.
Old Mar 28, 2013 | 04:37 PM
shbox's Avatar
Did you meter all the ground wires going back the PCM? (test continuity with PCM unplugged and meter leads at PCM connector and injector connector)
Old Mar 28, 2013 | 04:52 PM
ok a little confused. How do i test the ground wires going to pcm?
Old Mar 28, 2013 | 06:40 PM
ok so i ohmd the wires from injector connector to pcm connector and i get 2.0-1.9 on all of the injector connectors. Is that ok???
Old Mar 28, 2013 | 08:52 PM
Bump!
Old Mar 28, 2013 | 09:16 PM
Ed Wright's Avatar
9-Second Club
I always use a Fluke 98A digital storage lab 'scope to check the wave form. Check a couple of good ones for a reference. Back probe the ground side and ground the 'scope's ground lead to Batt -.
Old Mar 31, 2013 | 05:00 PM
I've never used one before and they seem to be pretty expensive. is there any other test I can do to the wiring harness? I think its one of my injector pig tales that are messed up
