Thoughts on monoblade TB?
Won't be for the whole RPM range, and not with street car parts, but it is definitely possible.
Doesn't change the fact that a 355 doesn't need even a 58mm, let alone a monoblade
. I have always wondered if my Monoblade was too much for my motor,but figured at WOT it would want all it could get. with the fast ez efi I can fine tune the iac circuit.
Think I should find a 58MM and try it?
By having to big a hole you lost the velocity which the engine creates a vacuum so by using velocity the maximum air is sucked in.
You want a balance between volume and velocity. Thats why large numbers on heads doesn't mean squat without good velocity.
You would need an 8000+ RPM engine to take advantage of those.
If interested, my SS 360" LT1 makes 600 hp with a stock TB, not even an air foil. Not legal where I race. Doesn't pull that much vacuum up high. Guys see the MAP climbing with the factory manifold and think they have a restriction. It's not really pulling vacuum, it's the MAP sensor location. It's the Brunelli effect.
Unlike boobies & peckers, bigger ain't always better.
