Save my car, LS1Tech!
Old Apr 1, 2013 | 09:07 AM
Stroked96Bowtie's Avatar
Originally Posted by ThoR294
only over 70mph, which leads me to believe its output shaft of the trans and back... nothing on the motor side. Its the same vibration with the clutch in or the car in neutral
Over 70mph in gear OR in nuetral over 70mph...same vibration. Only things that Ive ran into, similar issue to yours was with a driveshaft out of balance or wheels out of balance. Sometimes it doesnt take much to throw a driveshaft off, if it was dropped, etc...could do it. When you did the clutch change, did you use ANYthing from the old setup? Or was it ALL new? Then again, if it was on the clutch side you should be able to feel that giving it throttle in your driveway.
Looks like you've tried 2 diff driveshafts...same exact vibrations? Are the wheels new? Try to think about what you may have changed just before it started.
Old Apr 1, 2013 | 09:10 AM
96capricemgr's Avatar
Not likely the problem but in all my reading the pilot bearings are MUCH more troublesome than bushings, so if you find yourself taking this back apart I would swap that back to a bushing.
Old Apr 1, 2013 | 09:11 AM
ThoR294's Avatar
It happens in gear slightly, but virtually goes away when you hit the gas. If you push the clutch in, its real bad. Real bad in neutral, same intensity as pushing the clutch in.
Old Apr 1, 2013 | 01:16 PM
LightningTeg's Avatar
So if your rolling at 70 and put the clutch in it starts doing it badly? I would suspect a bad joint or drive shaft. When its under load, whatever slack in the system gets binded back up and you get less vibration it sounds like
Old Apr 1, 2013 | 01:20 PM
ThoR294's Avatar
Yes. You can kinda feel it while its in gear decelerating, but if you push the clutch in it feels like hell. If you accelerate it virtually goes away. I know, it sounds like and feels like a driveshaft. I've balanced and had 2 new u joints on the steel DS (which is in it right now), and an aluminum driveshaft out of an LS1 with new joints did the same thing. I'm going to measure it and throw a sweet PST driveshaft into it and see where that leads me.
Old Apr 1, 2013 | 01:43 PM
Get it up on a lift running and see if you can find the culprit
Old Apr 1, 2013 | 02:02 PM
93M6Formula's Avatar
Would bad motor mounts somehow cause a vibration?
Old Apr 1, 2013 | 02:10 PM
ThoR294's Avatar
vibration when you hit the gas on take off, or rev it freely.
Motor mounts keep the motor in place. So if the motor gets torqued, itll move around pretty good if the mounts are bad.
Old Apr 1, 2013 | 02:50 PM
Just throwing out ideas since about everything else has been covered.
Old Apr 1, 2013 | 02:57 PM
ThoR294's Avatar
haha yeah my next idea is LS1 car
Old Apr 1, 2013 | 03:02 PM
speedtigger's Avatar
Old School Heavy
You might have your transmission tail shaft bushing checked. When they are heavily worn, you can get a vibration that is more intense when the drive train is not loaded such as when coasting.
Old Apr 1, 2013 | 04:40 PM
  #32
93 LT1 Vette's Avatar
A constant timed vibration is generally caused by a rotating mass.
Driveshaft
wheels
wheel bearings
brake discs
tires
Ring and pinion
axle shafts
Clutch/throwout bearing
flywheel
pressure plate
transmission main shaft
crankshaft
pilot bushing in the back of the crank
harmonic balancer
crank pullies
power steering pump
alternator
A/C compressor
Now what on this list changes in neutral or when you push in the clutch or what do you unload that could cause a vibration that you have not changed or looked at.
Engine RPM's drops
clutch disc
throw out bearing
Drivetrain load lessens.
Old Apr 1, 2013 | 06:38 PM
  #33
nascarnate326's Avatar
axel bearings?
Old Apr 1, 2013 | 07:42 PM
  #34
F0x Slaughter's Avatar
I have my pinion angle set at 0. S60 was just installed and Strange driveshaft. Got on the freeway today for the first time and 80+ she was vibrating. Going to adjust the pinion angle and she how she likes that.
Old Apr 1, 2013 | 08:04 PM
  #35
ThoR294's Avatar
I have heard about this. Would both transmissions really have the same issue?
Driveshaft
wheels
wheel bearings
brake discs
tires
Ring and pinion
axle shafts
flywheel
pressure plate
crankshaft
harmonic balancer
crank pullies
power steering pump
alternator
A/C compressor
Engine RPM's drops
clutch disc
throw out bearing
the bottom half of the list is out of the question because its a vibration on the output shaft side of the transmission. I shut the motor off in neutral and its still there. this means the motor is not moving at all
Old Apr 1, 2013 | 08:41 PM
  #36
unioncarpenter84's Avatar
ive got the same problem just wana drive it off a cliff lol
i got new
umi lca
umi adj panhard bar
new qa1 shocks
new wheels and tires balanced
steel driveshaft balanced and new spicer u joints
new trans mount
tired poly mount
and it still does it makes not a bit of sence the cars did not come like this from the factory so its gotta be fixable!
Old Apr 1, 2013 | 09:08 PM
  #37
okay guys i think i may of found the issue im going to do this within the next few days
watch the last few minutes of this video on the link its bout the u bolts being to tight causing 80 percent of vibration!!!
wonder if this is true
i kno i crank mine down so it doesnt come loose
but heres the link
http://www.hotrodhotline.com/md/html...asurements.php
Old Apr 2, 2013 | 11:39 AM
  #38
chino_man279's Avatar
Thor the more you describe your problem the more it sounds EXACTLY like the issues I was having. I got to the point I thought the car was going to explode so I quit driving it.
Old Apr 2, 2013 | 11:53 AM
  #39
ThoR294's Avatar
I can jack my car up and put 2x4s under the rear wheels so I can get under the car and to measure the driveshaft (for PST)? or does it have to be completely level... (i.e. alignment rack)?
Old Apr 2, 2013 | 12:17 PM
  #40
I did mine in the driveway. I put a couple 2x4's under each tire so I could crawl underneath. Measured with a standard tape measure and called. If I remember correctly I got mine from Bob who is now at Brute Speed. Been a long time since I got mine... I just made sure the suspension was loaded the same as it would be going down the road.
