best way to clean lt1?
Old Apr 1, 2013 | 05:34 PM
HarleyZ28's Avatar
Default best way to clean lt1?
So my motor is in need of a good cleaning. It has a msd opti on it. Im scared to take a power washer to this thing I dont want to mess anything up. Whats the best way to go about this?
Old Apr 1, 2013 | 07:07 PM
myltwon's Avatar
simple green/degreaser and a rag is the safe way
Old Apr 1, 2013 | 07:11 PM
F0x Slaughter's Avatar
^ +1 One.
Do not shove a hose under the hood and start spraying crap.
Old Apr 1, 2013 | 09:25 PM
Spartan7's Avatar
Simple green on the block, brake cleaner on aluminum. WD40 works well for cleaning up plug wires.
Old Apr 2, 2013 | 12:29 AM
MasterTomos's Avatar
I just use soap/water and a rag for most things. Just keep up on it and it doesn't really become that big of a chore.
Old Apr 2, 2013 | 01:17 AM
popo8's Avatar
If the above options are not enough.. break out some towels, plastic bags, and tape, and tape off and protect all of the electrical and the the opti... and even then dont directly shoot any of them....
Old Apr 2, 2013 | 05:06 AM
96capricemgr's Avatar
pressure washed under hood with Delco optis plenty of times.
Old Apr 2, 2013 | 08:08 AM
97lt1camaro's Avatar
When I had my opti on the engine, I used a pressure washer on it as well numerous ones with no issues .
Old Apr 2, 2013 | 09:25 AM
SS RRR's Avatar
Village Troll
Me too. That's all I ever did when living in an apartment and was adamant on washing the car once or twice a week. Still have the stock alternator as well. Key is to never directly spray the opti.
Old Apr 2, 2013 | 09:38 AM
ThoR294's Avatar
I used simple green and a roll of shop towels from the zone...
Old Apr 2, 2013 | 10:05 AM
sweetbmxrider's Avatar
The key is spraying at a 37-42* angle relative to the direction of the rotor position in no more than a 5mph head wind.
Old Apr 2, 2013 | 10:45 AM
djjab57's Avatar
Simple Green and power washer here, Just dont soak the Opti. Never had an isuue
Old Apr 2, 2013 | 11:07 AM
SS RRR's Avatar
Village Troll
Given the water pressure you would then be spraying a direct stream onto the opti.
Old Apr 2, 2013 | 11:30 AM
lt4388stroker's Avatar
garden hose lol
Old Apr 2, 2013 | 12:34 PM
Rob94hawk's Avatar
Took my hawk to the car wash in the middle of winter to wash away any salt underneath and it idled high for a week. I'll never do that again.
Old Apr 2, 2013 | 01:36 PM
FormulaJoe's Avatar
I use a garden hose with my thumb over it, some soapy water and a big and small plastic brush. Power washer is overkill. The electrical connectors are made to keep water out, but I could see a power washer overpowering the connector seal. When I was learning auto body repair, during the detailing portion we learned to clean engine bays good. My instructor had seen power washers bug out car electronics before.
Old Apr 2, 2013 | 02:23 PM
marc97taws6's Avatar
My engine bay was very dirty as I only cleaned it once, but simple green, some towels, and some elbow grease!
Old Apr 3, 2013 | 10:11 AM
How else would you keep it clean?
Old Apr 3, 2013 | 12:39 PM
HellTeeOne's Avatar
I use a paint-safe dereaser/all-purpose cleaner and a small electric pressure washer. I try not to spray the opti directly and have never had any problems. Mine has the vented opti though.
I also leave the engine running as well so everything dries faster.
Old Apr 3, 2013 | 12:47 PM
Maybe it should be specifically said that many degreasers are bad for aluminum, like simple green. If left too long they will etch aluminum. If used quickly they are often OK.
Having the engine running helps too in that it is easier to clean grease and oil if hot.
