Pinion Angle and Vibration.
Old 04-04-2013, 09:27 PM
F0x Slaughter's Avatar
I was reading a thing from Hurst saying if you feel it in the shifter, its probably driveshaft balance in the front or u joint.
When I ran the car with the same exact tires last year before clutch, driveshaft, rear end was done it was fine. Tires were just in the garage, so nothing happened to them. I will check the runout. Switch tires front to back. Possibly pull the driveshaft to have it balanced. Strange is suppose to balance them but who knows.
Old 04-04-2013, 09:45 PM
armyinfantry3id's Avatar
best thing i would recommend is to try one thing at a time, then test, if switching the tires doesnt work then move on to the drive shaft, if that doesnt work, then move on to the next step, good luck with the diagnosis
Old 04-05-2013, 07:31 AM
ThoR294's Avatar
see my post. this is not a parts issue... something is out of whack somewhere lol
Old 04-06-2013, 08:27 AM
unioncarpenter84's Avatar
Ya mines the same way i still cant figure it out. Its good till 73 mph after tht it shakes whole car..
Its so bad u cant look out either mirror cuz there moving
Quick Reply: Pinion Angle and Vibration.
