lost oil press
Old Apr 5, 2013 | 08:32 PM
Bern1982's Avatar
Default lost oil press
Where should I start looking? What is the possibly of a spun bearing?
Old Apr 5, 2013 | 08:47 PM
Rob94hawk's Avatar
What were you doing when you lost oil pressure? And make a sig so we know what engine/year you're talking about. How many miles?
If it is an LT1 then check the oil pressure sensor in the back, oil level. If all is well then it may be time to yank the engine.
Old Apr 5, 2013 | 09:07 PM
myltwon's Avatar
Well if you have a bad bearing, typically it will make a sound. First thing would be to hook up a mechanical gauge and make sure it's not just a faulty sensor or bad wiring. Also need more info on what oil pressure you have, acceptable oil pressure in an LT1 is much lower than you might think. Of course if you're oil pressure is dropping during increased loads would be helpful.
Old Apr 5, 2013 | 09:09 PM
myltwon's Avatar
93 to early 94's had the oil pressure sensor above the filter IIRC.
Old Apr 5, 2013 | 09:39 PM
Bern1982's Avatar
I have a 97 z28 stock motor 131,000 miles. I was driving home when I heard the valves taping after a few more miles it got noticeably louder and the idiot light came on oil press was at 0. I pulled into a gas station and checked the oil and topped it off. Still sounds like it's not getting any oil. Car has been sitting for almost a year since. The car sat for about a year prior until I intalled the new opti and water pump. I have put maybe about 1000 to 1500 miles on this oil change in the last 3 years..
Old Apr 5, 2013 | 10:38 PM
RamAir95TA's Avatar
You may have stripped the oil pump drive gear (possible) in turn losing oil pressure. I'd pull the intake manifold first and see what's going on (after checking oil pressure with a manual gauge).
Old Apr 6, 2013 | 08:00 AM
leadfoot4's Avatar
If the lifters are clattering, you've got no oil pressure. Don't start the engine and do any more damage. Pull the intake, and then remove the oil pump drive gear and inspect it. See if it's stripped. If not, possibly the plastic collar that holds the pump's drive shaft broke, allowing the shaft to be displaced, and it's not turning the pump. If that's the case, you'll have to drop the oil pan and dig deeper...
Old Apr 6, 2013 | 12:17 PM
chino_man279's Avatar
I would follow leadfoot's advice. It sounds like the drive gear is toast to me.
Old Apr 6, 2013 | 05:19 PM
Bern1982's Avatar
What would you guys recommend as a replacement? Should I go with another oem part?
Old Apr 7, 2013 | 01:38 PM
leadfoot4's Avatar
Replacement for what part(s)?
Old Apr 7, 2013 | 02:19 PM
defaultexistence's Avatar
Yes OEM replacement oil pump drive IF it's toast.
Old Apr 7, 2013 | 02:34 PM
SoxXpupPeT's Avatar
definitely pull the intake and check the oil pump drive gear. Ive had them go out on me twice.
Old Apr 8, 2013 | 08:21 AM
quik95lt1's Avatar
how long did it run with no pressure?
Old Apr 8, 2013 | 09:08 AM
rich5368's Avatar
If it wasn't making any weird noises the first thing I'd do is put a manual oil pressure gauge on it. There is no reason to pull the manifold if all that happened was an electric sending unit went bad.
Old Apr 8, 2013 | 12:01 PM
Bern1982's Avatar
I ran about 2 miles shut it down called AAA and argued with the Guy about sending a roll back. But it does sound like there is no oil. I'm replacing the oil drive this weekend and doing the timing cover gaskets while I have it apart.
Old Apr 14, 2013 | 11:07 AM
Bern1982's Avatar
Bingo oil drive is stripped thanks for the info guys
Old Apr 14, 2013 | 12:03 PM
RamAir95TA's Avatar
You're welcome. Hopefully no permanent damage was done.
Old Apr 14, 2013 | 11:10 PM
SoxXpupPeT's Avatar
Ah man i know the feeling. Mine let loose a mile from my house at 1am... safe to say. It was one of the more interesting drives in my life making it home without burning up the engine.
Old Apr 15, 2013 | 09:43 AM
tricked94camaro's Avatar
my first reaction to no oil pressure is a very low oil level.
