stock rocker stud + guide plates?
Old May 11, 2013 | 01:35 PM
englundjd's Avatar
Originally Posted by BOOSTED AFR
Stud girdle, not cradle, and no there is no need for one until the camshaft is fairly large. Besides they require perimeter bolt valvecovers.
yea thats what i thought.
Old May 11, 2013 | 03:47 PM
cardo0's Avatar
Default Hardened pushrods.
Don't forget to use hardened p-rods with guide plates. Or use chromemoly p-rods. The guide plates will chew up stock p-rods.
cardo
Old May 11, 2013 | 10:11 PM
96capricemgr's Avatar
while buying good aftermarket pushrods is certainly advisable it can also be noted that the stockers up through I believe 95 ARE HARDENED and will survive fine with guideplates.
Old May 11, 2013 | 10:52 PM
DisturbedTA's Avatar
Thanks 96capricemgr that's a question answered for me and I didn't have to ask! Awesome!
Old May 12, 2013 | 12:56 AM
cardo0's Avatar
Where did u hear that? The self alinging rocker arms did away with the hardened p-rods. Lingenfelter said '86 was the year they changed and to check u need to drag a file gently across the p-rod and check for easily removed metal.
cardo
Old May 12, 2013 | 01:02 AM
BOOSTED AFR's Avatar
cardo
The file test has been done. Repeatedly. Through 95 they are hardened.
https://ls1tech.com/forums/lt1-lt4-m...-pushrods.html
Old May 13, 2013 | 12:51 AM
fex77k's Avatar
To expand on what you said.
Stud girdles are generally used in application that turn higher RPMs, they aren't as good as a real shaft setup. If rules or budget limit you to stud mounted valvetrain then it's a solution, it won't prevent catastrophic failure, but it will prolong it.
Old May 13, 2013 | 05:15 PM
englundjd's Avatar
i have non-stock pushrods but i can clean up my stock ones if the aftermarket ones arent hardened, ill have to look it up.
