stock rocker stud + guide plates?
another question; i was looking at guide plates on summit and i noticed it says machining required.... you have to machine your heads to use these? 0.o
and yet another question ... raised or flat guide plates?
But if not planning on turning high rpms, stay SA. A good SA rocker will hold up fine.
thanks for the part number ramair
Why are you so set on a 3/8" stud? 7/16" studs and rockers are very similar if not exactly the same price and they make for a more stable valvetrain.
Like someone else said....the lower threads on the stock 3/8" studs are too short when using guideplates.
on a different note someone i know mentioned to me about a cradle .... i wouldnt think that would be nessesary for my little cam tho
7/16 roller rockers.
