how to install ignition switch kit
now my question is how do i put this in? do i just follow shbox's ignition switch guide, tear the whole column apart, and it will get me there or is there another way to do this? If i have to follow shbox's guide and tear it all apart im prolly gona put a new ignition switch in it while im at it.
Now, if when you turn the key, it is not moving the rod, then the switch is not your problem (or not your only problem). It is either the key cylinder or the sector that translates the key movement to the rod. That part is in the upper part of the column and will require some upper column disassembly.
