Air delete and tune out
Old May 11, 2013 | 07:16 PM
jrwilliams95z28's Avatar
Default Air delete and tune out
First off thanks for all the help guys!
I tuned out my air system a while back but as I was tearing it apart I started the car to make sure my plugs sealed well and they did, but I noticed my air pump was pumping air still?
I tuned out with tuner cats using the constants table was that right? How come its still running lol
Old May 11, 2013 | 07:18 PM
BOOSTED AFR's Avatar
I'm not sure what values you put in the tables so can't help you there. But why haven't you just removed the AIR pump?
Old May 11, 2013 | 07:38 PM
I am removing the air pump and hoses/ hard lines I'm actually in the process of doing that right now. I tore the fittings out and plugged the holes before I put the car on wheel stands to get under it and remove the pump. When I started it I noticed the pump was still running.
I dident change any of the values I thought just turning it off in the constant table would have it off. Should I zero the values I just don't want the CEL to come on.
Old May 11, 2013 | 07:41 PM
Sorry, I misunderstood what you posted. I usually take it out there and set the parameters that activate whatever system I am deleting to values that the car will never experience. Be it MPH, or Coolant Temp or something else. Just to be sure.
Old May 11, 2013 | 10:33 PM
Ok thanks bud that's what I wanted to know!
