aftermarket Roller Rockers
I've read the stock springs are not the best so, assuming I need to change them as well, whats the best way to keep the valve from falling into the cylinder?
I've done spring/cam swap on my old dohc civic and I used compressed air to applied through the spark plug hole to keep the valves up while I changed all the spring but I am thinking thats not going to work with the LT1 given how hard accessing the plugs is.
can you bring the piston to TDC for each cylinder as you go to keep the valves from dropping out?
You can run stock springs with 1.6's no problem as long as you're not running a big cam. Just remember that the stock LT1 springs pretty much suck and will float the faster and further they're pushed, which doesn't take much at all, even under 6000rpms. This means you won't see much of a gain especially at higher rpms. So if you're going in to change the rocker arms, its definitely worth your time to upgrade springs, too.
that kit would work well if you not plannin on adding a cam... its what i have
thanks!
