measuring for pushrod length
Old May 8, 2013 | 09:30 PM
Camaro350Z28's Avatar
Default measuring for pushrod length
this is probably a worthless question since i think its a no but..
can i pull apart an lt1 lifter and make it solid to measure? im replacing the lt1's with the ls7's but i think the plunger may be different? is it different enough to throw off my pushrod length? didnt want to take apart my new lifter as ive never disassembled one
thanks
Old May 8, 2013 | 09:51 PM
BOOSTED AFR's Avatar
No need to disassemble anything. The LS7 lifters are hardly different than than the LT1s as far as plunger height. The same length pushrod for the LT1 lifters will work for the LS7 lifters.
Old May 8, 2013 | 11:10 PM
so just make a LT1 solid and check length off that one?
Old May 8, 2013 | 11:28 PM
I measure the entire plunger travel, then note it.
Then, with the plunger completely depressed i check the roller tip pattern and find a pushrod length.
After finding a length i subtract all but .050" of the plunger travel from the pushrod length to find the final length I need for the engine.
The .050" I leave in the measurement affords me the proper lifter preload. Viola! No need to build a solid lifter or anything.
Old May 9, 2013 | 05:53 AM
joelster's Avatar
Buy yourself a set of $6.97 checking springs. They are so weak that they won't compress a hydraulic lifter as you turn the engine over.
http://www.summitracing.com/parts/pro-66793
It's always good to have more tools at your disposal. These springs come in very handy for checking piston-to-valve clearance after a rebuild, or a head/cam swap.
Old May 9, 2013 | 07:50 AM
Ed Wright's Avatar
9-Second Club
^^^That's what I use. They won't kill an adjustable pushrods either. Use a Sharpie to blacken the valve stem tip. Adjust the pushrod length for the narrowest wiped pattern centered on the valve stem tip. Measure that pushrod length and order your new pushrods. Decked blocks, milled heads, different cam profiles, and different rockers all effect this.
It's well worth the effort.
Old May 9, 2013 | 07:55 PM
96LT1355Z28's Avatar
What Joel and Ed said!
Old May 12, 2013 | 05:51 PM
Bucksnbass's Avatar
good info, im new to this site and am soaking it all in. trying to get some posts in too !!
