motor mounts
I have to do the drivers side tomorrow. Any tips for the driver side?
If you don't have LT headers then you should have enough clearance to jack the motor high enough to slip the mount into place. I had to cut away some of the mount on the corners of the mounts for the top two bolts because the bolt flanges are a wide. No big deal.
I'm not sure what you mean by cutting off the tab on the drivers mount. A little afraid to ask...
We couldn't get the metal part that connects to the block to line up with the center of the prothane mount whether we did it off the car or on it. it only seems to fit without those tabs. also, they weren't wide enough to even hold the top part that connects to the block.
I haven't started the car yet and the engine seems stable on the passenger mount. Do you think I should get a different brand mount and try it or just go through with what I have now?
I read on someone else's forum post that the tabs could be removed, but then again that is just some guy on the Internet.
on to the drivers side...
I removed all of the bolts from the block except the one that is tight against the collector (stock manifolds). how am I supposed to remove that one? I am afraid to remove the collector pipe because it is pretty rusty and I don't want any studs to break.
That is what I mean. It looks as if it is resting on the brass tabs but they aren't actually there. I cut those off and the engine seems to be fine. I have NOT started it yet though. What do you think?
Now for your wrong doing...
You should have never cut those tabs. They are there to support and displace the majority of the weight of the engine through the mount. The next issue is you have the wrong mount on the passenger side. That is the drivers mount. Here is what the passenger side is supposed to look like:
And here is the drivers:
well I guess I'm going to pick up energy suspension mounts from autozone now. I'm sorry, this is why I ask questions! thanks so much for not being rude about it.
I ordered a mount for the driver side and I will be replacing it in the future.
Maybe climate plays into this?
I put fresh rubber in my car mostly because I had the front suspension apart enough to access the bolts that are inside the front crossmember on the b-body. I had had some headers hit the frame but it was cheap mediocre design headers that just needed more hammering. I did that with probably 165K miles on it, stockers seemed OK yet.
