24x coil set up let’s see them
Old Jun 2, 2013 | 03:05 PM
ascastil's Avatar
Originally Posted by BP Automotive
Here are my brackets. Although the OP chose not to go with them, maybe they will help you figure out what you want in some way. I have redesigned them a tad and cleaned up the design too.
I cant wait to see how these are gonna look on my valve covers!
Old Jun 2, 2013 | 03:16 PM
97LT1's Avatar
These are looking good. I put mine under the cowl area with an LS1 relocation kit. I will post pics next weekend when I make it back to the car. Unfortunately I have a head gasket leak or worse, so I will be tearing into it.
Old Jun 2, 2013 | 03:57 PM
SAPPER's Avatar
Bill's kit is definitely easy and a nice setup. I just chose to be different. I wanted my own setup and chose a different route.
Old Jun 3, 2013 | 03:39 AM
S10Wildside's Avatar
Here's a better view of the EFI Connection coil bracket assemblies. Click the following link to rotate, zoom, and even hide components for more detail. http://www.eficonnection.com/eficonn...-120-00025.pdf
The valve cover is transparent to show attaching detail.
These brackets were designed with the LT1 valve cover in mind. Notice the oil fill cap is off center. This is due to the location of the oil fill hole of the SBC valve cover. The LT1 oil fill hole is slightly higher and in the middle of the bracket hole.
Old Jun 3, 2013 | 06:19 AM
cucui's Avatar
Nice (eficonnection)but some of us are on budgets and can’t afford all that coin ($200.00 pr)
Old Jun 4, 2013 | 08:16 PM
lethal bird's Avatar
Still got to get plug wires, but still very happy with it.
Old Jun 5, 2013 | 02:16 PM
Dynamic396's Avatar
Here's my setup. I had a set of '04 truck coils, so that's what I used...
Old Jun 8, 2013 | 08:55 PM
383z's Avatar
Ya'll are going to make me feel self-conscience when I’m done with my conversion. Most of ya’ll have nice, clean engine bays, and crazy set ups.
97Z28SS nice engine, intake, carb set up.
Blackbirdws6 my jaw hit the ground when I seen your engine bay. It’s gorgeous! Do you even drive it?
CALL911 yours look mean and clean with that intake.
Sapper that is a innovative idea that you are implementing.
BizZzatch350 What in the world!? Nice engine bay and I don’t even know what kind of intake set up your using, but it looks good.
Dynamic 396 Damn, that just looks pretty.
I think I’m going to have to hit my engine bay with a tooth brush and paint before I post any pictures up on this site.
Old Jun 8, 2013 | 10:27 PM
96silverram's Avatar
S10 wildside,
The LT1 stock valve cover bracket looks amazing. Almost makes me want to put my old VC's on just to purchase that bracket
Dynamic 396,
What can I say...looks kick-azz
Old Jun 10, 2013 | 03:53 AM
Originally Posted by 96silverram
S10 wildside,
The bracket works with aftermarket valve covers, too. You only need to determine the difference in height and source longer bolts.
Old Jun 10, 2013 | 07:20 AM
SAPPER's Avatar
Finally got my valve covers finished up with the powdercoating. Placement on the right side is definately a factor on a B-body due to heater hose. But I got it right.
Also, I had ordered wires from Taylor. They are the 409 race wire. 135* boot on the coil, 6.5" between boots, 90* on plug. Somewhere around $80 shipped. I know they were $69.14 + shpng. If anyone is interested call Taylor and ask for Justin.
Old Jun 12, 2013 | 07:28 AM
  #32
SAPPER's Avatar
OK, let me change something. I got my wires last night and come to find out 11.5" with a 10.4mm wire doesn't work like a 8mm wire. I have to cut some off to make it about 6.5" between boots. A 90* on the plug side is a must and a 90* on the coil side would have been better.
I won't know about how good this is for an F-body until we get working on my neighbors Z. Plus his headers are alot different than mine. So we'll see. But these things are nice. I'll try to get up some pics tonite.
Old Jun 14, 2013 | 07:27 PM
  #33
BP Automotive's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Ill have some pics of my new style coil brackets up on Tuesday. I will still have the simple individual brackets for sale for you guys on a budget. The new ones will be a tad pricier, but I will be able to send an entire assembly with the coil sub harness and coils.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
Old Jun 26, 2013 | 07:08 PM
  #34
LS1Tech Sponsor
Here are the new coil brackets. I still offer the individual brackets as they will be cheaper for those on a strict budget.
The bracket in the picture is brushed aluminum, I will offer them possibly in painted and powdercoated. This will cost extra. I will just have to see what the demand is for some sort of coating on them.
I like the way they turned out, if you guys have suggestions as far as the coating goes let me know!
__________________
1-888-467-4491
Old Jun 26, 2013 | 08:35 PM
  #35
Shownomercy's Avatar
Man-Crush Warning
So the coils have to come off, then the bracket/cover can come off?
Old Jun 26, 2013 | 09:02 PM
  #36
LS1Tech Sponsor
Yes sir, I dont believe there is anyway to keep clearance for the oil fill and breather and get clearance for the bracket bolt.
__________________
1-888-467-4491
Old Jun 26, 2013 | 09:10 PM
  #37
I like that bracket!
Old Jun 26, 2013 | 10:40 PM
  #38
cucui's Avatar
what kind of coin($$) are we looking at Bill
Old Jun 27, 2013 | 02:49 PM
  #39
LS1Tech Sponsor
$150 for bare brackets with stainless fasteners
$200 for coated brackets with stainless fasteners
$450 for bare brackets, stainless fasteners, coil harnesses, and ls7 coils.
$500 for coated brackets, stainless fasteners, coil harnesses, and ls7 coils.
__________________
1-888-467-4491
Old Jun 27, 2013 | 04:17 PM
  #40
SAPPER's Avatar
Bout time you crawl out of your hole-in-the-wall down there. Thought we were gonna have come look for you...make sure you were still alive. Thinking maybe one of those venomous turkeys got you. LOL
BTW, They look sweet.
