How much does a shortblock weigh?
Old May 16, 2013 | 10:16 AM
bufmatmuslepants's Avatar
Default How much does a shortblock weigh?
I've seen from 230-403 on google, anybody weighed an lt1 shortblock? Just block, crank, rods and pistons. I'm trying to figure out if my brother and I can lift my old shortblock into and out of my escape with no hoist.
Old May 16, 2013 | 10:20 AM
3.8redbird's Avatar
Get a hoist
Old May 16, 2013 | 10:38 AM
SS RRR's Avatar
Village Troll
Bare block is around 180lbs. Add at least another 100lbs on top of that if it's a shortblock.
Old May 16, 2013 | 10:46 AM
BOLO's Avatar
Approx. 300-350#'s. If you have the leverage lifting it in and out of the engine bay which seem pretty tight and in an angle. I would at least use a cherry picker. GL.
Old May 16, 2013 | 11:45 AM
duh's Avatar
duh
My wife and I picked up a shortblock out of the back end of our trailblazer. Two strapping young guys should be able to handle it with out an issue.
Old May 17, 2013 | 01:59 AM
englundjd's Avatar
a buddy and i did it one day, one short block w/ pan and then turned around and did a bare block... dont kid yourself these things are heavy
Old May 17, 2013 | 03:49 AM
DeltaElite121's Avatar
I've done it with a short block before but it's a LOT of weight on your fingers. Took just two guys, though.
Old May 17, 2013 | 04:26 AM
lemons12's Avatar
I wouldn't want to do that.. I could see it being done.
Definitely wouldn't be fun.
 Michael S. Palmer
Old May 17, 2013 | 05:18 AM
VAformula's Avatar
True, but if the block has everything in it, I would never take the risk of trying to lift it with just two people.
Old May 17, 2013 | 05:47 AM
It's on a stand right now, not in a bay, so it's about at the height of the back of the escape. I figured one person with leather gloves grabs in the coolant passages for the water pump and the other grabs the fingers for the round handle that slides into the stand. I guess ill be putting my BUFMATMUSLEPANTS name to the test! Better buy some of those spongebob anchor arms... Or I can just barrow a hoist.
Old May 17, 2013 | 05:51 AM
97Z28SS's Avatar
Proform maks a set of aluminum handles that screw into the block and make it easier to lift and manuver, that"s how I move my blocks around and I think they're about $50.
Old May 17, 2013 | 07:29 AM
SS RRR's Avatar
Village Troll
I figured one person with leather gloves grabs in the coolant passages for the water pump...
LOL... no sir. Unless dude is a champion rock climber, that won't suffice. Just turn the block up side down and grab the front of the banks and put fingers inside cylinders 1 & 2. Other person can grab the engine stand mount. No problem!
Old May 17, 2013 | 07:31 AM
That actually sounds like a great idea and much easier haha
Old May 17, 2013 | 07:55 PM
fex77k's Avatar
Grab the block by the cylinders then you can set it on the one surface that doesn't matter(china rail).
Old May 17, 2013 | 08:03 PM
96capricemgr's Avatar
$20 engine dolly then drill it and put some angle iron across and take off the casters. Keeps the engine flat and level and gives a good handle. That is how we did engines in the back of my wagon. A shortblock is doable with two guys provided you have handles of some sort.
