Highest CR on pump gas?
Static compression is just the ratio of the combustion chamber size with piston at BDC to chamber size with piston at TDC. Piston design, head chamber, bore, stroke, gasket thickness and bore, and deck clearance set that. Dynamic compression is your true running compression.
Decided to just go with race gas and high compression, instead of risking using pump gas, I'll barely drive it so it'll be fine.
Thanks for your help guys!
Those calculations assume the engine is operating at 100% ve with no scavenging going on or anything like it. The whole thing just started so internet experts had another talking point to try to make themselves look smart.
Running high compression on a street engine (pump gas) requires that you have proper engine quench (ideally .035" to .040"), optimal dynamic compression (about 9:1 w/the LT1/4)....this is where the camshaft specs come into play....and a spot-on tune.
12.5:1 static compression is very doable when your build has been done correctly!
KW
