Having Tuning MAF issues about to be at ends WIT
Old May 25, 2013 | 03:45 PM
BADMOON's Avatar
Default Having Tuning MAF issues about to be at ends WIT
Car is tuned by one of the best tuners period....... Everytime the car is tuned by him the car runs awesome for about a month then it starts hunting for idle and runs a little sluggish. I never had this problem with the Speed Density tune. The car made 703/737 rwtq on 200 shot with the MAF .. Could this be a bad 02 sensor causing this issue? Possibly same one? This has happened twice now... I have a very big HR cam.. Could it be possible that it just needs to be ran on speed density tune.. I never had any driving issues with speed density..
Old May 25, 2013 | 07:18 PM
Ed Wright's Avatar
9-Second Club
It's not the tuning. It's the car changing. The tuning can not change. Dirty MAF, gunk around the throttle blades, dirty injectors, etc. Not being Speed Density sure isn't the problem.
Old May 25, 2013 | 09:25 PM
T/A KID's Avatar
Bad 02's can rick havoc on a lot of things especially idle. I tend to run Open loop idle for big cams since the overlap of the camshaft tends to trick the 02 sensors IMO. Id rather do a MAF setup any day over SD, did a 25x 26x cam with MAF only about a month ago, idles steady at 850.
Old May 26, 2013 | 05:22 PM
BADMOON's Avatar
Do you run Speed Density? If this car was only driven in nice weather would you run speed Density? I looked at MAF and checked all around throttle body. The setup is fairly new I would have a hard time believing injectors. Im thinking bad 02.. The car lives in a garage and is barely driven..
Old May 26, 2013 | 05:32 PM
Ed Wright's Avatar
9-Second Club
I have had several modified cars, had them cars both ways. There is no way the problem is the car having a MAF. They are less prone to have the issues you describe than a speed density car. You have something else going on.
Old Jun 14, 2013 | 07:22 PM
BADMOON's Avatar
Default Update.
UPDATE
I drove the car exactly 2 weeks ago and the thing drove without any issues. Ran perfect!! So I parked it and decided I will let it sit for 2 more weeks and just got done driving it without any issues.. Im real confused.....I havent touched it!! Not cleaned the MAF nothing.. The only variation is that the weather is Hotter...
Old Jun 14, 2013 | 11:55 PM
SPOOLED UP's Avatar
OK?
SO the hotter the weather the better it runs with 0 issues?
Old Jun 15, 2013 | 12:04 PM
BADMOON's Avatar
Originally Posted by SPOOLED UP
OK?
Yep. Drove it around for 30 mins. Drove like it should....
