o2 sim question
Old Apr 26, 2004 | 08:01 PM
warbird27's Avatar
Default o2 sim question
i went to order my o2 sims from summit just now, and i dont know which one i need, the 97-2001 or the 95-96 one. i called and they couldnt give me an answer and they said to check if it was a 4 point. i went under and it is hard to get to and i dont have the time really to pull things to get to it to see. i was hoping someone had a quick answer. i figured 97 would be different than the ls1's.
Old Apr 26, 2004 | 10:05 PM
OneMeanZ's Avatar
Hmmm....I thought the O2 sims would fit all OBD II, guess not.
Old Apr 27, 2004 | 05:12 PM
Formula96's Avatar
I have the 97 up on my car and no codes have been thrown
Old Apr 27, 2004 | 06:26 PM
BizZzatch350's Avatar
Moderator
Yea, I thought they were universal for all OBDII, only the V6s ODBII cars are supose to have problems with them because of the voltage.
Old Apr 27, 2004 | 06:36 PM
warbird27's Avatar
im wondering if i should spend the 100 bucks on them and the extensions or get it programmed out and add some power at the same time. would this work?
Old Apr 27, 2004 | 08:02 PM
Formula96's Avatar
The extensions are for your front o2's, you will need them for longtube headers. I believe that the front ones are to tell your engine how much gas to add so i woul'dnt try to delete those...
Old Apr 28, 2004 | 09:41 AM
-PEPE-'s Avatar
you need the 97+ 02 simms, they are 4pt, they are for the aftercat 02 sensor replacement, one is located right by your starter and the other is located by the transmission tailshaft area. They are 4-contact connectors about 3/4" x 3/4", same as the LS cars in 97.
Old May 2, 2004 | 10:36 AM
bakerelectronix's Avatar
O2 simulators are universal the only difference are the connectors. We have a Dual (only one is needed for dual exhaust) O2 simulator without connectors that we sell (currently on special for $24.99 and free shipping within the U.S) for any OBDII vehicle, you can splice it into your harness or onto your old connectors if you like.
Neil Baker
Baker Electronix
www.bakerelectronix.com
