Aluminum Radiator
While I do think the quality of the aluminum radiators China has been pooping out by the thousands has increased, you need to choose carefully. Many advertising not just two rows, but three and even four have very small rows with a good deal of airspace between the rows. This makes for a radiator that looks nice and thick but doesn't perform any better than stock.
If I remember correctly, the stock '96 and earlier have a single row 1 3/8" thick. So if the above radiator has two rows each 5/8" thick it'll actually be less efficient than stock. If 7/8" it could be a noticeably better than stock. Without knowing exactly how big the rows are, one can only guess.
I installed one of these Chinese specials (under a different brand name) in my Trailblazer and was actually rather impressed with the quality, given the price. However, I shopped around until I found a model that was two rows with 1" rows--total core thickness ends up around 2 1/8". Given stock was a single row about 7/8", this was a dramatic upgrade in that case.
This radiator looks to be inferior to that, and the stock LT1 is a much better starting point so I'm not convinced you'd get much, if any improvement in this case. It's too bad as it's always nice to have lower cost options that work. They're more expensive, but with Griffen or Be-Cool, you'll know what you're getting.
I went through every vendor thats selling these and asked on each core size.
Hopefully one will write back with actual sizes. I will report back with my findings.
Im not buying a damn thing until I can get actual core sizes though. A lower cost
option would be sweet, but we will see.
I ended up getting a Spectre radiator as a replacement, but the point I was making was the factory piece is awesome.
Here's a Champion 3 row with the correct connections
Thats the one I will go with. Thanks for the heads up, I totally missed
those key parts
Theyre local to me so I will stop in and checkit out beforehand!
I tried to order one of these from another vendor today and he said it would not fit my 1995 5.7 firebird. Said the fittings were different.
All the rows are not pinched, nor mangled. All free flowing. Welds and fittings
look great as well. I haven't installed it yet, but I will provide results when I do.
Here is some pics of it....
He was referencing the Champion catalog and said that is what the catalog said......and then concluded it would not fit my 1995 V8 car.
Well mine is going into a V8 car lol. The only thing I see is that if you put this
in a 98-02 Fbody, you will have to cap off the steampipe fitting on the radiator.
Im not sure if LS1 Fbodys had the low coolant level sensor like the LT1s did either.
It will fit a V6 car just fine, just cap the fitting.
a few years ago. So results from that aspect wont come from me unfortunately.
I still drive the car to most events (as you can see I don't even own a trailer for it) but every now and then, especially when taking the family it's easier to tow. MUCH easier to get home if you break the car!
It gets the job done fine for an occasional tow but it's certainly not ideal. A few times a year, OK, but every other week all summer and you'll be wanting something better.
They were offered in the later years with the V8 and while they're probably more expensive on the used market it would make towing life easier. They're also all setup to drop a hot LSX into whenever you feel like it--doing the swap with an I-6 poses many problems.
