coolant? help
You then need to take the plugs out and do a pressure test. You can rent a tester at any parts store. Do a search on pressure test as well.
Also when we put in the thermostat we dumped over a gallon of coolant into the water pump without tthe thermostat so it would go into the block and it could still of taken more we then put more coolant into the radiator could it still need more coolant I know the say. The block and radiator together take around 15 quarts
