Another Racetronix thread
Racetronix custom Walbro-GM Teflon in-tank harness
High-pressure non-kinking 'Flex' fuel tube
New Push-Lock fitting
Stainless gear clamps
Custom 30-micron high-flow fuel sock
Assembly adhesive & lubricant included
How much grief is it to use or reuse any of these thing I may not get with another pump?
Hey Ed, I certainly don't have more than you but I was told that at wide open throttle on 36 lb injectors, a stock pump will run the car lean. I've had nothing but issues with my racetronix Walbro and wouldn't mind swapping back but always get scared hearing this from forum members as well as track buddies etc.
