What's the biggest cam you ever daily drove?
Old 07-07-2013, 03:43 PM
  #41
td1168's Avatar
I drive my ms4 on a daily basis in the summer here. It bucks if you get down below 1500 rpm's in gear but thats the only issue I have. These bigger cams aren't drivetrain friendly as far as longevity but I'm just answering your question.
Old 07-08-2013, 01:36 PM
  #42
KW Baraka's Avatar
Originally Posted by NewOrleansLT1
What's the biggest and I mean THE BIGGEST cam you guys run in your daily driver.. 230/236 110lsa for me..
242* intake duration with 12.2:1 compression.
KW
Old 07-08-2013, 02:41 PM
  #43
Mystery Bird's Avatar
242/248 110 LSA, 4000 TC, 4l80e and 3.90 gears drives just fine, when properly tuned.
Old 07-08-2013, 10:21 PM
  #44
Blue85350's Avatar
My last truck had a 240ish* comp cam in it. The previous owner installed it, and didn't tune it. It sucked really bad, I didn't keep that truck long. I also drove a friends truck for a little bit that had a comp 244* cam in a 434 small block. It drove pretty good and I kick myself in the *** for not buying that when he offered it to me.
Old 07-08-2013, 11:50 PM
  #45
SS MPSTR's Avatar
246/254, 108 LSA, 0.640", 385CI, A3...naw, not daily driven.
Old 07-09-2013, 03:50 AM
  #46
lemons12's Avatar
DD my Ms4 car for 2 years..
DDing my 408 right now.. 24X/25X
Old 07-09-2013, 04:01 AM
  #47
02sleeperz28's Avatar
233/239 cam. No issues when I had it. Drove around with that cam for 3 years.
Old 07-09-2013, 04:03 AM
  #48
GREENMILE's Avatar
i dd a 228/232 628/632 112 on my old 5.3 gmc ext cab. it wasnt that bad. i liked it actually.
Old 07-09-2013, 07:11 PM
  #49
BADHAWK51's Avatar
I drive mine where I want no issues.
249/257 .612 107LSA 383ci
Old 07-10-2013, 12:34 AM
  #50
NewOrleansLT1's Avatar
You guys are running some serious cams out there!!
Old 07-14-2013, 06:52 PM
  #51
Moderator
BizZzatch350's Avatar
If the tunes nailed down, it won't be an issue. My C6 has a 228R, 93 has a CC306 driving around the 93 sounds meaner but doesn't drive worse. My 398 has a 254/260/110 LSA cam in it, solid roller. I think that set up should be pretty fun.
Quick Reply: What's the biggest cam you ever daily drove?
