having trouble connecting to pcm
what do these 2 wires go to? my only idea was the AIR pump which was deleted. this is drivers side front of the engine, you can see the coil
http://i1286.photobucket.com/albums/...ps258ad44d.jpg
my ground strap is frayed but not cut, i'd imagine its still working just fine tho?
What ground wires are on the back of the heads?
Should be replaced. I have some 8 guage ground wire around here somewhere is that overkill enough?
http://shop.advanceautoparts.com/web...ontent=5701635
