Losing my mind. Arcing problem
any progress?
well my 5 cents are that the coil may be putting out too much spark???
is your ignition stock or do u have msd and msd coil?
if you read my thread on no spark. i was going nuts trying to get it and in the end it was something real simple.
so keep at it.
theres not a whole lot in the ignition system that can cause wild sparks like that.
thats why we all want a video. snap it on your smartphone(iphone plug)
and upload it to youtube and put the link in here.
make sure you dont have dielectric grease on the boots and plugs.
ground is the biggest issue. i would goto auto parts and get new ground straps.
take yours off and that way you make sure to get the correct size.
let us know...
forgot with my upgrade i also put in 30# ford red tops. but i doubt injectors would be an issue as all them seem like they are firing
im the resident t/a fbody guru here in hialeah.
i saw a buddys car do something similar a few years back.
to make a long story short. what made it arc was the autozone guy sold him a grease to put on the spark plug threads claiming they are aluminum heads and steel plugs so they wont bond or sieze to the head.
we cleaned it off the heads and plug threads and problem solved.
so i would take out a plug and see if theres any kind of compound on the plug head threads maybe.
lemme find the instructions on how to perform it exactly.....
anyone else can chime in if ya remember off the top of ur head.
the wires themselves do not arc as much as the msds did but arcs will still come out of them if they can reach a ground.
bury me or my car please.
Im trying to brain storm here, wires, plugs, heads, cam, intake, tune. thats all new stuff after build. intake cam heads i highly doubt are the issue. wires and plugs have been checked numerous times. tune is only other thing new. unless i had something else magically happen while my car was on jackstands for 2 months?
